I have a question for a while now. I have a Spyderco sharpmaker with UF rods. Do i really need to strop after every sharpening or its optional for hair whittling. If i've asked a blasphemy question, im sorry.
Well, i use a wide variety of steel. Mostly s35vn. But it can go from d2 to REX45. Yes, d2 responds really well to stropping. But s35vn and 20cv/m390 feel the same with or without for my usage.Depends on the steel IMHO. High carbon steels respond to stropping better than the high carbide super steels.
Definitely strop, it may not necessarily make it sharper but in theory it should extend edge life a small bit coming off of a sharpening. Once the burr is sheared off it can be jagged at a microscopic level, so you can refine the edge down to where it's a bit more stable. A lot of times when you use a knife it will develop tiny rolled areas on the edge that can simply be unfolded and straightened by stropping, so when it comes time to touch up it's better to try to strop rather than immediately hit the sharpening stones. Once stropping stops working, then it's time to sharpen, which does remove material and uses up the blade.
