- Feb 27, 2010
I got a 25 as a gift but see that the Umnumzaan has an over travel stop on the newer models......Was bending the lock an issue? All my ZT's have them, but I always felt it was more for looks.
It's not needed and I personally find it hard to believe there was really enough knives messed up by their owners for it to need to be introduced. I don't know if it was a descision made after seeing 1 knife or 1000 knives, but it could/should have been executed in a different way, IMO. Using a pin or plate on the inside of the lock bar would have dissolved most if not all dislike for it and still hit all the same targets.
I'm good though, I have enough original Umnumzaans to last me a lifetime and more.![]()
I bought my first Umnumzaan , new, about a month ago. After spending some time with it I couldn't quit thinking about how ridiculous the people that had problems over extending the lock must have been.
It really works perfectly.
However, as one previous poster noted, this knife was geared towards heavy use under stressful situations-- and when that happens the operator could apply extreme force and deform the lock bar.
That was my guess too and still think that is the reason for the over travel stop (Not a stabilizer) being there.
If you've ever heard Rick Hinderer's reasoning behind creating the Lock-Bar Stabilizer, it's because under stress in turnout gloves with his adrenaline pumping he wasn't thinking about how much force he was using on a knife lock and bent it too far which rendered the knife useless.
I dunno. For better or worse I think it was to prevent further warranty claims from guys loosening their lock bar tension to make the knife flick open faster. I don't think closing the blade using extreme force, under stress is as much of an obvious consideration as deploying the blade and using it under stress. As mentioned the new umnums only have a simple over travel stop, not a stabilizer that protects the lock bar from being crushed upwards under use.
I don't mind the appearance of the OTS. I prefer the looks of the only pivot.
Maybe opening, but closing a knife under adrenaline pumping stress? Look, Hinderer put a tactical spin on the pedestrian truth - lockbar stabilizers protect the knife from customers, and reduce warranty returns. Why? Because 'tactical' sells, whereas the truth might cause resentment as it has for more sensitive types and purists.
OP:
Do you have gorilla hands such that when you hold a glass it shatters?
Have you ever bent a lockbar before?
Do you feel compelled to modify the lockbar because you know better than the designer?
If 'no' to all these, then no you don't need it.
OP:
