I have read (and felt) all the concerns over the years about accidentally disengaging a liner lock due to grip or torque. This makes sense. I have never had it happen, but I certainly see how it could.
It seems to me that the PERFECT solution to this problem which one might encounter with 'normal' liner locks is COMPLETELY negated in the design of the Spydercard!!!
Imagine if you will, a large Spydercard of a more conventional shape and size, with the addition of G-10 scales and a very slightly larger hole to release the lock.
With the exception of total lock failure (which I think is usually much less of a concern than accidental disengagement) I don't see ANY way in which a lock such as this could accidentally disengage!!!
Why, then, has this not become THE way to make liner locks? Am I the only one that sees how great this is, or am I the only one that is missing some obvious reason why it's not a FANTASTIC idea?
-John
PS - for those of you not familiar with the Spydercard, it is essentially a liner lock with only liners for handles. If you look at a photo of one the hole on the left side of the handle is where you access the liner lock to close the knife. I hope that's an adequate explanation. Take a look at the photos here, I think they make it pretty clear: http://www.onestopknifeshop.com/store/spyderco-spydercard-info.html
-John
