It depends. The Wicked Edge is arguably one of the best systems available and I use it for just about any knife except my Victorinox and traditional style pocket knives as for these I still use my 30 year old Lansky.
The optional low angle adapter would solve most problems...
so is the wicked edge worth the 300+ dollars? what makes it so different from the lanksy system? does it work better or is it just all talk?
Hi Andrew,
With the Lansky I can sharpen my Victorinox knives at an angle as low as 13.3 degrees but that is a bit too low for me so I use the 20 degrees setting which gives me an actual angle of 17.4 degrees per side.
The Lansky clamp went through a number of redesigns over the years but the original design was the best, this is the thread in which thread in which it was discussed:
http://www.bladeforums.com/forums/s...hnique-for-EDC-newbie?p=14898206#post14898206
Fortunately, Lansky also realized that they made a mistake and as of this month they have brought back that original design: http://lansky.com/index.php/products/multi-angle-knife-clamp/
Frans
On the angles, though, I confess I'm a bit confused. If you use the 20 degree setting on a narrow blade such as the Vics have, wouldn't that result in an angle more obtuse than 20 degrees (rather than more acute at 17.4)?
You can also use Tormek's small knife jig in the W.E...
...it doesn't work very well with multi layer knives where the blade is not centered in the knife.
Besides that... a complete 5 stone Lansky set is about the same price as just that Tormek jig
