I did it in my homemade, backyard ghetto style propane forge. Electric would be nice, but anything with a pyrometer would be perfectly fine. As Tim pointed out, even judging by eye works well if you're well-practiced at it.
Here's what I did, pretty much in the order that I did it, in nauseating detail.
First I read a lot. McCreights book is good, Hrisoulas as always, lots of websites such as the ones already mentioned, and
http://www.mokume.com , and I talked to several people that I knew that had done it. Aside from many people here on the forums, I also spoke with Steve Bloom, who has been helpful to me at every turn.
I gathered materials. Mostly from Ebay. Keywords that I looked for were "shim stock" and "copper foil". Kensimp has a pound of 22-30 guage copper foil up for auction on occasion, and is a great guy to buy from. I may have also bought the Precision brand brass shim stock from him as well, but I'm not sure. I also used some nickel silver that I purchased from the Blade show.
I made a small press out of 3/8" 304 stainless. I used four stainless 1/4" bolts from Home Depot. Galvanized anything doesn't go in my forge. I cut the copper, brass, and nickel silver to roughly the same size pieces. (Around 3" square) Put them in the press with a bunch of C clamps and squished them all flat, or at least flush with each other. Then I took them out of the press and cleaned them with a commercial "Professional" copper and brass cleaner. Then I cleaned all of that crap off with 220 grit sandpaper, using disposable rubber gloves stolen from the hospital.
Stacked up the pieces on a piece of cleaned heat treat foil and put a piece of broken pencil next to the stack, then folded the whole mess up into a nice, tight envelope in the press, as tight as I could get it.
Took it outside, brought the forge up to heat, and laid it inside. Took about ten minutes to get it to what looked like the temps it needed. I put a piece of copper foil on top of it all, thinking that it would melt at the right temp. This was a mistake. The foil oxidized and kept its shape, telling me nothing of value. Next time I'll use a chunk of the lower melting point metal.
When I realized my mistake, it was because of the color of the press. I knew I'd have to overheat a little bit because of the thermal mass of the press and layers in order to make sure that the center of the stack bonded as well, so I let it soak a bit longer at what I thought was the proper heat, then pulled it out, tapped it a couple times with a two pound hammer in the center of the press, and water quenched the whole mess. Took almost as long to cool it as it did to heat it up. Had to grind off the foil in some places, but it worked well. Due to the overheating and slightly too long soak times, the copper and brass fused and made a pretty red brass between the layers of nickel silver. Next time I'll suck it up and sacrifice the outer layers and not use the heat treat foil so I have a visual reference.
There you go, mistakes and all. Even an amateur like me can do this, if determined enough. My next try will be better.
