is this a leaf spring
i found this on the road a few weeks ago, its a little more then 30 inches. im not gonna make anything with it until i finish my other knives, but i just want to know if i should keep it or not. if the image doesn't appear then click this link http://tek26007.wordpress.com/2014/03/12/is-this-a-leaf-spring/
it has an small arch shape similar to leaf springs but i dont know much about them so i just want someone who knows something to look at it
You could cut off a piece, HT it , and see if it hardens well.
When you photograph something please remove or cover all extraneous stuff in the background . It will be less confusing.
Something to consider, that leaf spring broke off for a reason. It's probably full of micro cracks and would break if made into a knife. For example, the right side of your picture there appears to be a lot of pitting or a void in the steel. I'm not sure if forging the piece could make it stronger, or get rid of micro cracks. Others may have that answer.
I asked a similar question when I first started on the forum and the answer was NO. The forging heat is not hot enough to weld up the cracks. So you are taking a chance, certainly with a hard use knife or cold cut. But a lot less strain is put on a skinner for example.
I think it's just a dirty cement floor, but good advice.
Props in photos don't ususlly add much.
I'd keep it it's ten cents per pound
I'd say no. Leaf springs are assembled With a pin at the center and clamps toward the ends. That means only one hole. I think what you've got there is a fuel tank strap or something that fell off a rig. How thick is it?
Overload springs don't always have a pin hole in the center and have bumpers on the ends through small holes. But, I also think probably tank strap that's been run over...For several reasons. If it isn't about 1/4" thick, and ain't springy (flip it over and bounce on it) it isn't a spring.
At any rate, even if it is a spring, it's still a hunk of mystery steel. And full of stress fractures...
-Eric
-Eric
"When you photograph something please remove or cover all extraneous stuff in the background . It will be less confusing."
It's a dirty shop floor. Not at all confusing.
That was a general comment --to all . When I look south all I can see is the Pocono Mtns -it's confusing !
I believe that piece of metal is part of a battle ready katana that failed in use. It should be taken out into a field and buried with respect. Burry it deep so no one disturbs it again.
I forged 6 knives from some 35 year old Chevy springs a while back, pounding them from 3/8 down to 3/16ish and i'll be damned if every one of them didn't warp back to the original arc of the spring during the quench, I used the proper quench method, warmed the oil to 130 degrees lowered the knife in the oil sharp edged down with no side to side motion, I figured that spring steel must have a memory to some degree
That's definitely an overload spring with holes in the ends and not in the middle
I also normalized the steel too ;0)
