- Apr 3, 2011
just got it in and never used one before so wasn't sure
Maybe a sticky plunger on the dial? Try moving the plunger with your finger and see how responsive it is.
Glad it worked out for you. I'm always amazed at how consistent these things areNailed it! Removed and checked and it was spongy. added a drop of oil to the plunger and its working perfect now.
Thank Hoss for your reply. I start to think the same thingIf it were me, I wouldn’t mess with it, especially if your getting accurate readings with your test blocks.
Hoss
You may be right my friend. It makes sense as in my ames, the line of the viewfinder is perfectly lined up with the start line of the dial. So maybe it's from the factory, maybe is from the recalibration some years ago...who knows...it just works fine.Mine has a bit of bend in it too. I think it's how they're designed. Definitely don't try to straighten it.
BTW , I own an Ames 1/2" ball penetrator which i don't need and want to sale. I noticed that sales are not allowed here by ordinary members. Any thoughts where could I upload it?
Thanks again
Hello, maybe is too late to ask (after 5 years) but may I ask what and where is this plunger? How did you manage to have access to oil it?Nailed it! Removed and checked and it was spongy. added a drop of oil to the plunger and its working perfect now.
Sorry I don't recall at this point!Hello, maybe is too late to ask (after 5 years) but may I ask what and where is this plunger? How did you manage to have access to oil it?
Thank you
Sorry ,I don't understand what is the "plunger " on the dial..could you upload a photo please?I'm actually curious about how to fix the plunger too. I gave a model 2 tester to a friend who can't really use it because the plunger on the dial indicator is stuck. I've heard that oiling it could actually make the problem worse by mixing oil with dust and gumming it up. I could get it to work by exercising the plunger a couple of times to loosen it up, but that's far from ideal for a precision instrument.
I believe it’s part of the dial indicator. They sometimes get sticky and don’t move smoothly.Sorry ,I don't understand what is the "plunger " on the dial..could you upload a photo please?
