I order my self a Ka-bar TDI Law Enforcement Ankle Knife not to long ago.
Yes the one in this photo.
When I examined the knife I notice it had a few dull area's, or where the very edge, flatten ever so slightly.
It was still sharp and could somewhat cut hair off of my arm. That night I begin to work on the edge, and put a convex edge on it.
Max grit I went up to was a 600, then stropped it on some leather loaded with green compound. The edge came out very sharp and was able to cut hair a lot better then the factor edge.
The next day I would play with it in a way. I would pull it out here and there, not really cut with it, but just pull it out of it's kydex sheath.
Eventually I examined the edge and I notice the edge yet again had some minor area's where the edge flatten a bit or started to go dull.
However I did no cutting. I assumed this was from the knife cutting the inside of the kydex sheath every time I would pull it out, even slowly...
So I stropped it again, and brought the edge back. I decide to do a little bit of cutting. I cut up several slices of 1 banana, and the edge was fine. I then moved on to a orange. Cut it up, then carved the skin away from the orange.
I examined the edge again, and once again it had area's where the edge begin to go ever slight dull. When I mean dull, I mean, I could see the edge flatten out in some area's. I would see a bright silver line on the edge where it appear to be going dull.
Is this normal for this steel? AUS 8a ss.
I thought maybe it was heat treatment on the knife, then again I hear a lot this knife is consider a "last ditch knife". Not sure if that has "certain meanings"....
What are some ways I could test it to see if this heat treating issue and not just the steel it's self?
