is this normal
The blade on my small Sebenza is not quite centered in the handle when closed, it sits just a little to the non locking side of the handle when closed is this normal ? sorry no pic
Sam
I have limited experience with Sebenzas (only had 5 so far), but every one of them, both sizes and handle variants, have had centered blades. Someone with more Sebenza expertise that I have will check in shortly, I'm sure.
no, that is not normal. it should be centered.
it could be the bushing or bushing screw is improperly set.
have you taken it apart recently, or was it purchased as used?
Mine is a tad off-center but I can live with it. The blade does not touch the handle slabs. If it bugs you, CRK will make it right.
Some of mine are not perfectly centered. I don't worry about it. they don't scrape the sides, they're just a little off.
Try taking it apart and then reassemble. I know that sounds a little redundant on this forum, but it does work.
I think it is more of an illusion than anything. Don't look at the blade but just the tip. Is it centered between the handles? If so, you're good. If not and reassembly doesn't help, contact CRK for their opinion.
