Wow. Than you for the very detailed explanation. I'm thinking of buying Deluxe Tinker. I hope that model doesn't have the problem...It is and it shouldn't be.
It's not supposed to happen. I've had plenty of classics in the past without this issue. In recent years it has become increasingly common to see factory new classics with this exact same file rubbing problem. I complained about it to Victorinox and they told me to send in for warranty. I never bothered. It's not worth the hassle.
I should probably also note that this is also seen on other models. As far as I know, the Ambassador has always had a similar issue with the end of its file scratching the knife. The Sportsman would be another example, and I think they made it worse when they changed the file texture. Also basically any model with 2 knife blades on the same layer, or a combo tool on the same layer as the knife, has a slight rubbing issue where the blades touch. It's usually not very bad and a lot of people actually never notice it.
Another thing to note: the Rambler/Manager has an outward facing file and therefore is immune to this problem. It also has a key ring on the opposite side of the knife blade so that it can't get in the way when you are using the knife.
Victorinox QA is not what it used to be. I feel theres been a certain 'cutting of corners' with production is recent years.
