jiminy said:
So why do you say there isn't a different curve for different quenchants and/or different 'recipes' of 1095? It only stands to reason that there would be. Where does it state that all 1095 follows this exact pattern under all circumstances?
1095 is what we and the industry calls the alloy of steel. The name is derived from a specification (i.e. AISI 1095). The standard/specification calls out ranges/tolerances of the alloy's chemical make up. Alloys that are within the called out ranges are considered to be 1095. There can be be an infinite number of alloys that would still be called 1095.
Through emperical testing they derive the TTT curves for the alloy. The TTT curve is for the range of chemistries that the 1095 specification covers. There will not be one for each variable or quenchant. You can also see the curve i posted is also for 1086. So one curve is good for two alloys.
Now talking from experience from working in the Automotive industry for 10 years, we rely on standards and specifications. One place I worked made door beams for side impact occupant safety. They heat treated
50 miles of steel tubing
per day for the products they made. The steel was certified coming in the door to garauntee that it's chemical composition was within spec. By no means did they change their processing variables and tune them for each lot or chemical variation that was within the called out standards. A certain sample size was tested to make sure the process was running as it should. The testing was not based upon which lot the steel came from, but it was a set number of pieces per shift. This would set up statistical conformation of their heat treating process. It did not matter what the tube's OD or wall thickness was, it was all heat treated the same way.
The TTT curves are setting your heat treating process and if the steel you are using satisfies the standard that that TTT curve was derived for, you are good to go. Yes there are going to be some slight differences in the hardened steel, but I doubt there are many knife makers out there that would be able to quantify the differences that you would see from the varying chemical compositions. That is the whole idea behind standards and specifications.
The TTT curve is the TTT curve. Like Fitzo said, it is all on how you remove the heat from the steel. To transform the austenite to martensite in 1095 it has to be cooled according to the curve for 1095. It is that plain and simple, no questions, no arguments. It can be colled faster, but not slower.
It is independant on what you use to quench the steel. If you use water it can cool it quicker than oil, but if you use the proper oil you can get the same as quenched hardenss as you do with a water quench.
The TTT curves are also independant of blade shape and thickness. If you are quenching an extremely thick blade and the outside gets to martensite, but the center doesn't, the steel is still following the TTT curve. You just did not remove the heat fast enough to form martensite in the center of the cross section. No unique TTT curve is needed to tell you how to cool a 1 inch thick blade or a 1/16 thick blade in oil or water or air. Martensite is formed or it is not and for martensite to be formed the steel needs to be cooled according to the TTT curve.
I guess I don't completely understand what point you are trying to make either. 1095 is 1095 whether it has 90 points of carbon or 103 and is different and will have a different TTT curve than the TTT curve you displayed for 1065 steel. Each alloy has its own TTT curve, there is not one "master curve" for all steels.
