Applejacks
BANNED
- Dec 9, 2006
That's pretty poor :thumbdn: it looks like (not good) freehand sharpening.
Do you think its possible, that this is in fact not a new knife??
The real question I have on this one is this:
Is the sharpening angle different across that edge? If not, that different height sharpening bevel tells me that the actual primary bevel grind is uneven.
The edge is straight, so an uneven sharpening bevel either means more metal was taken off in one spot than the other, or the primary bevel varies so that the same sharpening angle takes off less metal in one spot than the rest.
I don't think it's been resharpened, from what I can see. The actual grinding marks in the edge itself are too perfectly perpendicular for this to be a hand sharpening job, and I can't think of a sharpening system that would shape an edge like that. Looks like a factory job to me. I would post about this over in the SOG forum and see what they say about it.
Can you compare it to some others?
Sometimes our aesthetic expectations of knife grinds run counter to the difficulty the maker has in producing thousands of the same blade, or even his view of what he was trying to do.
It's his call, and if it doesn't suit you, he will probably exchange it happily. But it may be exactly what he settled on to distribute.
I've seen similar problems with spyderco knives and queen/Schatt&Morgan. It's a factory knife, if the edge is sharp, what's your complaint?
My guess? Its uneven sharpening rather than uneven blade thickness. They pushed a bit harder at the tip than everywhere else and brought back the bevel a bit more. It may even be intended that way....sharper thinner front edge, thicker stronger primary edge...
That was so over my head.I was looking at this pic closer:
I noticed something i did not before....this blade has a americanized tanto tip, but look at the primary grind line...it does not appear to follow the edge shape. For instance, on a curved tip, usually you want the grind line to follow the shape of the blade which then creates the front of your distal taper as that grind line passes the spine....it appears here that the primary bevel was ground straight to the tip regardless of if the edge turned upwards. If that is true, then the edge thickness at the tip may indeed be thicker before sharpening than the primary cutting edge....
Picture taking a square bar of steel and grinding a long straight bevel in it with no tip. Then take a saw and cut an angle to form a tip. Obviously the steel thickness along that angled cut will be thicker towards your new tip than the steel along your ground edge...now sharpen that tip, and youd end up with the same grind you see here.....just a hunch....
I have no experience with knife sharpening sir. I fear messing up the blade even more. hahaha
