- Sep 19, 2022
Hello all. So, I ran across an issue with Damascus I hadn't before and am wondering if there is a way to fix my mistake.
I have a small mini-forge and it isn't deep enough for me to bring an entire 8 1/2" blade up to temperature before quenching.
As you can see by the coloration in my metal (pic attached after forge), after heat treating there is an obvious difference between temperatures the blade was brought up to.
After tempering twice at 400F. I evenly sanded all surfaces back to 600 grit before etching in FC. Now you can see there is a difference from a black to gray right around the line where the steel was heated to proper temp and where it was not. (pic attached after etching, another pic after etching)
This wouldn't be as big of a problem if the handle covered the entire tang, but, because of my design (pic attached shows layout of handle and exposed metal) and using antler for handles I am purposely exposing the metal at the upper part of the flat/recasso below the jimping, also, the part of the tang between the index finger and other fingers, and again behind the last 4 fingers.
My questions to someone with more experience than I are:
Do I try to heat treat again focusing on the handle part of the steel?
Do I try to flat grind the surface of the blade and try etching again?
do I just live with what I have?
Thanks so much for your time.
Jason
Pics below:
after forge
after etching
Jason
Pics below:
after forge
after etching
