- Mar 3, 2012
So I've taken my sebenza apart a few times, just wanted to see how easy it actually was to reassemble and I've heard so much about the tolerances. I'm not disappointed at all, it's pretty astounding how well everything goes together.
Only problem is that I just took it apart to grease the bushing and washers, and after putting it back together the blade is just barely touching the backspacer when closed. I only realized because I noticed a slightly more metallic sound when closing now, which appears to be the blade barely contacting the backspacer . It's odd, hasn't happened to me before, everything is smooth as butter and the blade is centered. The backspacer appears to be perfectly in line with the lanyard hole too (no lanyard in) so if I moved the spacer it would start to show unevenly through the lanyard hole. Any ideas?
