Aluminum can leach off under hot temps (burner use) esp when cooking acidic foods or foods/drinks containing tannic acid (tea) or cooking fruits (acidic). Daily use CAN accumulate aluminum in the body, particulalry the brain and brain stem.
When I worked at UBC here in BC Canada, one fo the researchers at the Alzheimer's Research Labs did extensive testing of aluminum cookware to find out how much aluminum was leaching off. They found SIGNIFICANT amounts when acidic foods or liquids were cooked, tomato sauce was the worst. Hard anodized pots fared better, but as they wore/aged the concentrations became higher. Worst of all was bare aluminum pots that had seen extensive use and had micro and macro pitting on the surface - the amounts of leached aluminum PER SINGLE USE with acidic foods were equivalent to a full years dose of aluminum (when a normal smooth surface pot was used.)
other studies they did were surveys of the families of Alz. patients, as to the frequency of use of aluminum cookware. It was found that over 70% of Alz sufferers cooked daily with aluminum pots, and cooked acidic foods (beans, soups, sauces, fruits etc).
Aluminum "self protects" itself by forming a constant layer of "corrosion" on the surface. Its microscopic powder that does dissolve nicely in hot water......
food for thought. I prefer stainless personally but have used aluminum cups in the past.
EDIT: I should add that there are MANY other factors that contribute to Alzheimer's....aluminum is only 1 - 2% of the equation
