It finally happened ... Knowledge + Experience = Peace Of Mind
I noticed the favorite kitchen knife needed a sharpening, out came the Shapton Glass 500 grit stone. Apply water use various stroke styles, grab some paper, slice... good.
I know it can be better ... grab the Spyderco Medium Benchstone add soap, water and a few, super light, edge leading strokes dropping the angle more acute each time ... sliced some paper ... better.
Time to gild the lily. Spyderco Fine, soap, water, extra-super light edge leading strokes, up-back, up-back, paper, slice ... there we go, my best. (Rolled the last piece of paper into a tube and then sliced the top off the tube ... ziiiiip). =) Boy that's fun.
The above took about 6 minutes to do this morning and about 2 years to learn.
Thank You all for your help these past years. For too long I did not know how to sharpen. I read a lot, watched a lot, called folks, e-mailed, DVD's, books, and a bunch of frustration. So much paper cut over time with not ever knowing why it would or would not cut. Now I know enough to finally be at peace with my knife sharpening.
There is a calmness to knife sharpening now ... it's a special feeling. So much more to learn and refine, but for now, I know I can sharpen a knife freehand and it's not too shabby.
Special Appreciation to Jason B., Peter Nowlan, Bill DeShivs, and Josh of Razor Edge Knives.
Thank You - John
Congrats brother it's taken me a while myself....occasionally I will get a knife that has an uneven grind from the factory usu.near the ricasso it throws off my game till I see it,then I know I'm in for a little extra work
Thank You.
That extra work throws you when you're not sure what to do or how to do it.
Now, "I can fix that, and I'll need "such & such" to do it." Man! I like that feeling.
Good for you John! I don't understand what I quoted above though. You take a finer stone and drop the angle? How can you hit the apex if you drop the angle?
And with "... up-back .." I assume you mean you increase the angle a bit (microbevel) and than back to "main" cutting bevel to reduce the microbevel further?
Thank You - John
Way to go !
Hey . . . while you have the paper rolled into a tube try shaving a layer off the side of the tube without cutting all the way through it. = Next progression of sharpness.
If you can get a layer to shave off in both directions the edge isn't rolled and there is no bur.
Do this for the whole length of the edge . . . from a six minute sharpening session . . . and I bow to you Grass Hoppa'.
