- Nov 29, 2010
I also posted thus in the general forum, however since this IS the cold steel subforum, it seems only fitting to post it here as well! It has also been reformatted to hopefully address some concerns.
I also recently contacted Andrew Demko regarding the hole by the blade. So I'll be including his response here:
"If you have a USA made 4MAX then a .187" (3/16) pin should fit. However the intention in production was not for that use so a little adjustment to the hole or chamfering may be required. Also the Italian made knife is slightly under .187" and would require drilling/reaming as I dont think a smaller pin with ball detent is available. " - Andrew Demko
Post #1 and #2 will be all pictures. Posts #3 and #4 will be sectioned pictures
So I have decided to clean my 4max, and since there is no detailed overview of each of the components within a 4max, or a tear down at all from what I've seen. Since this is not necessarily a review, simply a parts overview, I am not sure if it belongs in the review section.
I will have two ways to view this. Either categorized by section, or simply as a "View all" style button.
ALL pictures
The Locking Mechanism - there is a comfortable gap between the lockbar and the blade when deployed, giving room for wear in
Teardown Overview - I'd like to make a brief note ,that the prybar in the upper corner was absolutely necessary in taking down this down. I did however, wrap it in tissue paper to ensure it wouldn't scratch the titanium liners!
The Hardware - There are three barrel screws for this knife which hold the spring in place (Barrel screws are all stonewashed). This means that they are under very high pressure loads since the spring on this knife is just a monster (we are talking pounds worth of pressure applied to the lockbar). The roughly 1 milimeter difference in barrel length for the upper screw really messed with me, as I accidentally dropped the tool mat and didn't realize the length difference. This resulted in the short barrel going in the wrong hole, and then 30 minutes of struggling to get the barrel out of the hole (as it was under high amounts of pressure)
The Pivot Screw - Seems to be made in house. Well machined! The pivot is also stonewashed
The Springbar and Backspacer
The backspacer -This backspacer has a notably disappointing segment where the interior is very rough. This caused gouges in the steel of the spring, which is somewhat disappointing. Spacer is stonewashed
The Spring - The spring is somewhat gouged, however this was likely due to the rough interior of the backspacer (Do note, the gouging on the spring looks worse than it is due to the grime)
ALL pictures
