- Nov 29, 2010
Hey folks!
So I have decided to clean my 4max, and since there is no detailed overview of each of the components within a 4max, or a tear down at all from what I've seen. Since this is not necessarily a review, simply a parts overview, I am not sure if it belongs in the review section.
EDIT: I was testing the waters to see if this sort of content would appeal. Unfortunately, it has be 'spoiled' by an argument over the formatting. As such, if I feel so inclined to attempt this again, I will be sure to an add "All Pictures" button for those who simply wish to scroll through the pictures.
The knife:
The Locking Mechanism - there is a comfortable gap between the lockbar and the blade when deployed, giving room for wear in
Teardown Overview - I'd like to make a brief note ,that the prybar in the upper corner was absolutely necessary in taking down this down. I did however, wrap it in tissue paper to ensure it wouldn't scratch the titanium liners!
The Hardware - There are three barrel screws for this knife which hold the spring in place (Barrel screws are all stonewashed). This means that they are under very high pressure loads since the spring on this knife is just a monster (we are talking pounds worth of pressure applied to the lockbar). The roughly 1 milimeter difference in barrel length for the upper screw really messed with me, as I accidentally dropped the tool mat and didn't realize the length difference. This resulted in the short barrel going in the wrong hole, and then 30 minutes of struggling to get the barrel out of the hole (as it was under high amounts of pressure)
The Pivot Screw - Seems to be made in house. Well machined! The pivot is also stonewashed
The Springbar and Backspacer
The backspacer -This backspacer has a notably disappointing segment where the interior is very rough. This caused gouges in the steel of the spring, which is somewhat disappointing. Spacer is stonewashed
The Spring - The spring is somewhat gouged, however this was likely due to the rough interior of the backspacer (Do note, the gouging on the spring looks worse than it is due to the grime)
Part 2 below!
The knife:
Part 2 below!
