This is just a thread for people to post things that are useful and which do not seem to be common knowledge.
So to get things started.
Leukoplast medical tape(often called classic due to vast array of different tapes now in existance)
IT was used by the Germans in WW2 and they had far fewer casualties from wounds then other powers in part because of it, Israel now uses it for its soldiers in a turn of irony and its found to be very effective.
I was wrong and Israel does not use Leukoplast, sorry about the incorrect information.
The official PR
"Leukoplast consists of a high quality viscose backing coated with a zinc oxide caoutchouc adhesive.
It ensures a high initial and permanent adhesion. Due to the porous coating of the adhesive Leukoplast® is permeable to air thus reducing the risk of macerations. The material is extremely resistant to tension. Leukoplast® contains natural rubber latex which can cause allergies.
Main uses
Fixation of wound dressings on normal skin
Securing of tubes, catheters, probes and cannulae"
Resent studies have also found its a great replacement for sutures, especially on parts of the body that previously other methods were not effective due large amount of stretch/contraction.
You can also use it as mole skin for blisters, it works fine as cover for small wounds, stopping dirt getting in while your working in muck or keeping flies off. If you get a large roll 5cm wide it works as a pressure bandage or for tying splints to a broken/sprained limb.
It also has many non medical uses a person who camps/backpacks and likes to roam out yonder will find useful.
Can be used to temporary patch tears in backpacks or clothing, add a grip to handles on knives or other tools that's grippy yet easily removed.
If you use resin and coat it as you wrap it will greatly reinforce what you wrap it around and dry hard... almost like a bushversion of epoxy and fiberglass tape, great for attaching a knife to a stick to make a spear. If torn off into strips and then rolled on itself can make cordage quickly.
My grandfather was a fisherman all his life and its what he used to cover cuts nicks and scratches for most of it(no gauze). he would heat a strip up over a flame source then slap it on the wound, it would adhere instantly and wouldn't even come off in water. Further his wounds when it was applied this way healed quicker and I suspect the heating sterilizes the tape and the outside of the wound when its applied hot.
large 5cm wide 9m(30feet) roll weighs about 85 grams (3 ounces) pretty light considering it can replace alot of other medical supplies like bandaids and steri-strips.
Just don't buy the stuff made in Africa(I don't know why but its crap and won't stick)
Hopefully at least one person will find this helpful and I look forward to seeing what items others have found useful.
The official PR
Main uses
