Tis indeed Sunday... I could sleep all morning, but noooooo way in hell! Time to entertain, feed creatures, and slap myself into reality!
Time to make the donuts..
And how do I drill through hardened Super blue steel? Cobalt bit just spins.... Sit and spin!
Edit: lycosa, yes. Potatomeat.
Potatomeat? umm ok
Drill hardened super blue - lasers, you'll need 6-10 of those gas station ones and a magnifying glass.
You might be able to soften the tang with a torch and drill, not too sure on super blue as it has some alloying... I'll look and see.
(just checked, yes you should be able to - hold the blade with a wet rag and evenly heat the area, go slow and alternate sides. Be careful about heat and remember with uneven heat it can warp...)
The standard way to drill it is with a carbide bit, something I have no experience with. You need a rigid setup as otherwise the bit will likely shatter.
Hey Daniel, would any of the drill bits I have access to work for Sloth?
I feel for you, having a 4 day old is work and theyre not even out of the hospital yet. *Shhh* Frank just malice clip one of those baby carriers on the back of your plate carrier vest and its all good.
Hope your all having a great weekend.
