dkb45
- Dec 16, 2012
I've always had absymal performance with S30V. Razor edges that dull away from a hard look, working edges that just don't cut very well (roughly slicing paper). Also lots of rolling, but I found out that was from using a stropping compound too soft to do more than wear away the matrix around the carbides. I figured I have one that thing to try before I write off S30V for good. Diamond stropping compound. Apparently that was the missing component.
I got pretty cheap compound off of Amazon, figured no point in trying expensive stuff if it does nothing. Cut some MDF into paddles and loaded them. So far I have 2 paddles, one with 20/40 micron and one with 16/10 micron. I took my Paramilitary 2 finished with DMT red and stropped it on the 40, felt the edge and it seemed pretty decent. Shockingly keen for 40 micron, but just as aggressive as I would expect. Proceeded to 20, and the edge could shave (not super well, but still shave), and kept every bit of aggression. Push cutting receipt paper with ease. Thought this would be good to test.
Took the knife to work, cut up around 10 1x1x1 cardboard boxes, cutting them into small pieces to maximize the number of cuts. 16 cuts per box. End result? Still sharp, still shaving (albeit pretty poorly now), slices receipt paper with ease, and snags but still push cuts.
I've never had this kind of performance with S30V. I didn't think it would ever perform this well for me. Nowhere near my favorite, but if you treat it right it sure as hell performs. Finicky as all get out, but finished right it's so much better than I thought it could be.
