The best edges I've been able to get, have come by working an orderly range of grits, using one specific method/technique, in only one abrasive type, such as all diamond, or all silicon carbide (wet/dry sandpaper). It's difficult to produce predictable results by jumping from a 'coarse-medium-fine' stone (who knows what the abrasive or actual grit size is?), to a '220/600' grit diamond hone (or vice-versa). Grit numbers usually won't translate across abrasive types, sometimes not even across different brands of the same abrasive type. If you're looking to get a different sharpener/system, get something with at least 3, and preferably more stages, all in the same type/make of abrasive. A relatively simple and inexpensive way to test this strategy, would be to get some wet/dry sandpaper in a grit sequence of (for example) 220/320/400/800/1000/2000. Cut pieces of the sandpaper to fit on top of your existing hones (your Tri-Hone, for example). In this manner, you'd still be utilizing your same skill set, using an apparatus that you're familiar with. Only difference would be the abrasive at work. BUT, since it's all the same type/brand of abrasive, in an orderly grit sequence, the transition from one to the next will produce much more consistent and predictable results. If your technique is good enough to produce a shaving edge now (with the tools you're currently using), you should see very good results quickly. As with all sharpening, focus on the fundamentals of consistent angle and light pressure, and INSPECT the edge closely (good magnification and bright light), as you go.
