I have no personal experience but I've seen a couple for sale in the forum (none that were fiddlebacks I believe) and the largest problem seemed to be stains on the ivory micarta from leather sheaths. The white really shows EVERYTHING.
Thanks for chiming in guys. This knife will not be a heavy user. It's more of a picnic knife. Ivory micarta is really nice in person.
http://www.tmxaerospace.com/wcm/idc/groups/internet/documents/web_content/mdaw/mdi5/~edisp/dw022352.pdf said:NOTE: MICARTA PRODUCTS IN THEIR NATURAL STATE DO NOT PRESENT AN INHALATION OR CONTACT HAZARD, HOWEVER OPERATIONS SUCH AS BURNING,
WELDING, SAWING. BRAZING AND GRINDING MAY RELEASE FUMES AND/OR DUST WHICH MAY PRESENT HEALTH HAZARDS
PHENOL 108-95-2 <8-12 5.0 ppm 5.0 ppm
5.0 ppm 5.0 ppm
FORMALDEHYDE 50-00-0 <2 .75 ppm .30 ppm
METHANOL 67-56-1 <10-11 200 ppm 200 ppm
MOLYBDENUM/ 1317-33-5 10 mg/m3 10 mg/m3
DISULFIDE
SILICA 60676-86-0 0.1 mg/m3 0.1 mg/m3
SILICON 7440-21-3 5.0 mg/m3 10.0 mg/m3
CRESYLIC ACID N /A <4 5 ppm 22.0 mg/m3
This product is a thermostatic composite consisting of a cured phenol-formaldehyde on a cellulose substrate. OSHA PEL and ACGIH TLV have
not been established for this material. Formaldehyde has been designated a carcinogen on the following lists: NTP/IARC/OSHA
Precautions must be taken when formaldehyde is present In the air at concentrations greater than 0.1 ppmas described in the standard.
HAZARDOUS DECOMPOSITION PRODUCTS Carbon dioxide, carbon monoxide, phenols, methane, formaldehyde & hydrocarbons
Dust Or Fumes May Be Produced During Welding, Burning, Grinding And Possibly Machining. Refer To ANSI Z49.1
EFFECTS OF OVEREXPOSURE:
Acute Dust or fume may cause irritation to the eyes, nose, or throat. Inhalation of Formaldehyde dust or fume may cause cancer.
Chronic A very small number of exposed people may develop an allergic reaction after prolonged or repeated exposure.
Phenol Exposure may cause skin irritation and liver and kidney damage.
Formaldehyde Exposure may cause irritation to the eyes, skin and respiratory system. Formaldehyde is designated a carcinogen on the NTP/IARC/OSHA.
Methanol Methanol has tested positive for carcinogenicity in rodents.
Molybdenum Exposure may cause skin and respiratory irritation, and liver and kidney damage.
Disulfide
Silica Exposure may cause skin and respiratory Irritation. Silica crystalline as a respiratory dust has caused lung cancer in animals.
Silicon An accumulation of Silicon in the lungs may result in benign pneumokoniosis.
Cresylic Acid Exposure may cause skin and respiratory irritation, and liver and kidney damage.
Note: Consult your regional codes or Code of Federal Regulations, Title 29, Part 1910. Subpart G-Occupational Health and Environmental Control, Subpart I
Personal Protective Equipment. Subpart P-Welding, Cutting, and Brazing, and Subpart Z-Toxic and Hazardous Substances. Certain welding type activities
may produce hazardous substances such as carbon monoxide, ozone, phosgene in the presence of certain chemicals, or produce Inert suffocating
atmospheres in addition to the production of ultraviolet radiation and/or noise.
Ventilation: Local exhaust or ventilation systems sufficient to maintain exposure levels to contaminates below prescribed limits may be required
When inhalation controls are not sufficient to reduce the exposure below the applicable exposure limit then use OSHA/NIOSH approved respiratory
protection within the use limitations of the respirator.
Personal To avoid contact use appropriate protective gloves or clothing to protect against cutting edges Appropriate heat shielding garments should be
Protection: used for activities using or generating heat. Eyes should be protected by using safetyglasses, goggles, helmet, face shield as appropriate to the operation
emoney2277 said:class up a picnic and slice a nice prosciutto and arugula sandwich with bree on a toasted brioche bun drizzled with a roasted red pepper aoli
Its one of my favorites from back when I was buying Bark Rivers. It is durable, and wears well. It cleans up easily too IMO. Mostly with washing. Dyes such will stain it and require scotchbrite type attention.
