IWB Knife sheath.
blgoode
Inside Waistband/ Conceal Sheath
This is my standard pouch sheath converted to an inside waist band sheath. I have detachable belt loop lengths to accommodate different belts. The screw that holds the belt loop also allows for a pivot movement that adds to the comfort.
This turned out well.
The belt I have on is a 1 1/4" belt. You can see that the loop will accommodate a larger belt. The slack fit allows for the sheath not too bind up when bending or shifting around in a car.
Knife is my SideKick / 6.5" overall model.
Thanks for looking.
In the last image you can see where a larger 1.5" or 1.75" belt would pull the slack in the loop down. I made a shorter loop for smaller belts.
****This post is also in the gallery. I was just so excited I wanted to share this here as well.
Good looking design, though I don't know how I feel about an inside carry, seems like it'd be easy to stick the knife somewhere other than the sheath! :o
I know!! This is for a Law Enforcement Officer. He wanted this not to stand out and have this as a backup. We'll see how he likes it. It rides nice though. The chicago screw allows for it to pivot.
I hope he doesnt get stuck ;)~ :confused: :D
Is there anything on the inside of the sheath that keeps the Chicago screw from scratching the handle?
I ask because I am trying to make IWB sheaths, myself.
- Chris
Chris,
The only thing that seems to get rubbed by the smooth side of the screw is the handle. Not the blade. What I did is give a little extra room so it wouldnt rub HARD against it. It doesnt really seem like it will be a problem but it may burnish the loveless bolt and cocobolo some. So my answer is NO. Just try to put the screw where it will rub the least amount.
Brian - did you not get my email answer to your question about countersinking/protecting the inside?
Anyway here is how I do it for all to see....
When I do use rivets or Chicago screws, etc. that leave the heads exposed on the inside of a sheath or holster I "countersink" them slightly by taking an exacto blade and cutting a VEE shaped countersink about 1/4 the thickness of the leather. This sets the heads just enough below the surface that metal doesn't touch metal.
You can also use a counterbore drill like you use for countersinking grip bolts or a woodworkers spade bit, with the "tit" ground down to the correct diameter.
I desired you can then take a piece of thin (2/3 oz) vegtan and glue over the rivet/screw head. After gluing in place very carefully skive/sand the edges out to a feather edge. The little "bump" this makes can actually act as an aid in blade retention. With Chicago screw you can also grind the head flat and then cover with the leather - this will lock the screw in place as well.
Will - I've carried IWB sheaths quite a bit (usually worn mid back) and when built right there's no more chance of sticking oneself than with any other concealment type sheath. One thing that helps is to build the sheath so the the inside top edge has a flap above the mouth.
Nice Job Brian
I just had a service man send me a SOG to do the same for.
but like Chuck said you can run that leather up a bit on your skin side.
I'll also use a skive to make a flap and counter sink under the Flap as needed
for screw, snap backs and rivits to cover them,
then cement the flap back down.
an idea to address the screw rubbing against the knife:
I've seen some sheaths with a lower oz. leather patch over the rivets/screws to help stop this, just glued right over it.
but I'm sure you have already thought of/seen this idea :footinmou :D
Thanks for the comments guys. I tried to make the mouth of the pouch a tad large so it would be a little easier to get the knife back in without getting stuck. Plus it takes the snugness off the screw and knife handle.
Do you have a standard belt loop on the opposite side for outside carry as an option? Also moleskin is another option for covering the screw head on the inside of the sheath.
Scott
I thought about having that as an option. Really all it would take is putting another hole in the opposite side. I just didnt want to put a whole in the guys sheath :D :D :D HE can of course. He should get it in a couple of weeks, and I am anxious to hear how he likes it. It may be the best sheath I have made yet. Very simple though.
Here is the smaller "regular" size belt loop
Its a much better fit but with a larger belt the other would be just fine.
