Izula accessory question
Ok, so i got my Izula kit. Been playing around with it today...
I accidentaly let the whistle/cord end click together before I was ready. doh!
Is there any way to get that little sucker apart again?
I just got my Izula kit today as well, and did the exact same thing. There is a way to get the whistle apart again.
Simply slide a credit card down each side of the whistle until you depress the stops on each side, then push the whistle out of the end of the holder.
A narrow bladed flat tipped screwdriver in the side and a twist works fine without wrecking anything. I have switched the whistle between the lanyards on two Izula's no bother.
Got it.
Ha! RAT Survival buiseness card saves the day.
Though probably not quite what they had in mind...
I had poked around with my SAK tweezers, but i hadn't really looked at the thing carefully and had no idea what to try pushing on.
Thanks.
The whistle seems to work great without the cord end thingy on it - makes a better fit in a "tiny" kit. Might risk losing it if your hands are real cold tho.
If I were going to carry it seperate, i would use both peices, and with about 1" of paracord to make a tiny loop.
You could even toss it on your key ring that way. :)
