Izula Actual Size Photos?
I suggest you find a picture of an Izula (easy to find) and then scale the image to be exactly 6.25 inches long on your screen.
Save the picture on your computer. Open the image and using a ruler make the tip to butt 6.25. Usually scrolling your mouse wheel increases the size of displayed images.
Use a picture resizing program. You can find one online if you don't have anything on your computer. Or I believe you can use MS paint as well. Then it's trial and error. Keep resizing the pic until the knife in the picture measures 6.25" on your screen.
Most web browsers will let you hold down CTRL and scroll the mouse wheel up or down, or press CTRL-+/- to change the size.
Here's a length pic.
I'm not good enough to balance the Izzy and a quarter and take a decent pic I guess (tried)...
but from handle end to where the blade begins is just about "2 quarters worth" thick.
not sure this helps ya...but hopefully.
HI CutleryMaster62 -
Here is a picture that is a little bit larger than real life -
best regards -
mqqn
best regards -
mqqn
That thing's as long as my USMC Ka-Bar fighting knife. It doesn't matter what the poster puts up on his PC, it's what the monitor resolution of the viewer is set on. ;)
This.
You would need to know what screen size the original poster has, and what resolution and then get yourself the same and do the thing again.
Hi cziv - while is is true that if you view this on a large screen with a large resolution the image could be as large as a Buick, the actual resolution of the image I posted, when viewed at actual size of the image, is just a little larger than the actual size of an Izula, and that is what the OP asked for.
best regards -
mqqn
