Hi guys, I picked up an Izula to use at my current part time job, overnight at Target, so it involves lots of opening and breaking down boxes. While I realize that a dedicated box cutter works better, it's the one pleasure I get out of that place, to be able to be able to use my knives freely. But i've run into a slight problem.
Excited about using my knife, I began use it to cut the packing tape, and break down the occasional box into smaller portions. I'd say, 75% of the cutting time on packing tape, 25% actually cutting boxes. And by the end of the first hour, my edge was pretty much blunted. Razor sharp, to being able to run my finger across it.
At first, I thought, okay, maybe the tape is gunking up the blade or something. So I cleaned it that night, sharpened it with my sharpmaker on the 40 degree setting, all the way up to the ultra-fine rods, and then went to work again. Instead, I only used it to cut the few boxes that I had to break down, and no tape. I used my Gerber EAB box cutter for the tape. And again, by the end of the first hour, after maybe 5-10 boxes, it was completely blunt again.
I figured at this point, perhaps the edge was fatigued from the factory grinding process. So I took it home, and did the standard 30 degrees to knock the shoulders down, and a full sharpening on 40 degrees from course to ultra fine. I figured that the 'newer' metal underneath would be better.
Unfortunately, that night, I found the same thing to happen. Blunt after about an hour of work. I've repeated the sharpening process a couple times now, with the same results. My Izula just can't seem to hold an edge. My sharpening skills aren't terrible, in fact, I think I do quite well with my sharpening setup. Just a sharpmaker and the Ultrafine stones.
Over the past couple months of working there, i've used a quite a few knives to do this same job. My Spyderco Delica with its VG-10 steel worked incredibly well, burning through all the tape and boxes with only a touch up on the ultra-fine stones at the end of the week. My Spyderco Persistence with its 8cr13mov steel needs a touch up every night, or every 2 nights on ultra fine stones to get its edge back.
Does this performance sound right for the 1095 steel in the Izula? I'm really only getting through 5-10 boxes before completely losing my edge. I'm quite confused, especially when my Persistence is outdoing it. Could it be a heat treatment issue? What do you guys think? And what should I do? Thanks for your help, guys. I really want to enjoy this knife, I'm just not sure what's going on with it.
