- Jan 5, 2017
I am a sharpening newbie, just look in my kitchen, all my knives are dull. After viewing a bunch of videos on YouTube, I decided on a King deluxe 1000 stone, a King S-3 6000, a King nagura stone, made my own sink bridge to hold both stones, and glued some veg tanned leather to a piece of 2X4 that also fit on my sink bridge for a strop. I got some green stropping compound for the leather and started sharpening. This was going to be a 3-step process and scary sharp was what I was aiming for.
First step with the 1000 stone went okay, I cut into the stone a couple of times but finally got my strokes down where I was only applying pressure when the edge was trailing. I maintained my angle as well as I could but still managed to scuff up a few places above the cutting bevel. It's not super pretty but I think I can fix it later with the buffing wheel on my Grizzly.
On the second step with the 6000 stone is where I have my question. while I was making the sink bridge and fitting it for the slightly larger 6000 stone, I chipped a fairly big piece off the top. I didn't realize it was so fragile. I had already removed the stone from its cheap plastic base at this point and scraped the glue from the bottom so I thought, I would just sharpen on the bottom un-chipped side. Good idea, right? There was discoloration on the stone from the glue but it was flat and smooth. Immediately I notice the 6000 stone was reacting differently than the 1000. I was leaving lots of black streaks. I used the nagura to erase these and to create the slurry it was made for and started again. Same result. Now I'm thinking that discoloration is some glue solvent that seeped into the stone so I flipped it over to work on the top, chipped side, but I notice the same black streaking effect. Now I'm not sure if I have completely messed up this stone by bringing some glue solvent to the unglued side with the nagura or it's normal to get much more black streaks than the 1000 stone? The slurry from the nagura on the 6000 is a little glue-like and not like the 1000 slurry without nagura. Has anyone ever done what I did or am I the only idiot? I would just buy another 6000 stone but it cost me $37 and I'd like to salvage it if I can. Maybe sand it down where the discoloration is gone?
