- Mar 6, 2017
Hi,What is the best brand of waterstones to get a sharp edge? Im currently thinking about a ninwa superstone.
Japenese
Actually, for actual sharpening (read not rough grinding) waterstones are going to be the most difficult to get high sharpness as you constantly have to deal with loose abrasive plowing into your apex which equals blunting. Fixed abrasives like diamond plates or vitrified bond aluminum oxide/silicon carbide will be much easier to attain high sharpness.
Also curious, what types of stones did you mean by vitrified alumina/SiC?
1095 440c 83r13mov 1428cn Aus8 154cm and VG10
Not any super steels but 440c 83r13 Aus8 154cm 1428cn ATS34 1095
Something along the lines of Norton's Crystolon/India, whereby using oil as lubricant is needed to keep the stones from glazing over and cutting aggression high.
The problem with trailing passes to get around loose grit plowing into the apex is that it tends to drag up a burr which will cause your edge to fail quickly in use.
In all honesty, with those steels I think you'd be well served with a coarse/fine Crystolon combo stone along with an Atoma 1200 to finish the apex.
Right on brotha, Those are sintered stones not vitrified. the abrasives are fused without binders or minimal binders, very hard bond and high porosity so its clogs with swarf and needs to be dressed at times since it doesnt reveal fresh grit. but it resists dishing.
The vitrified bond is a glass like bond, used in higher end, watersoaking stones like the nubatama, gesshin, and other stones in varying types of bond hardness, cutting speeds and dishing.
these are different then the magnesia and resin bonds.
I personally love "shapton pro" series stones. They are hard, they cut any steel, and resist dishing. Even the lower grit stones are really hard "which is a good thing since lower grit stones tend to dish like a mother".
The thing maggot brain said about raising a bur is incorrect. You have to raise a bur on one side before switching sides anyway. You should also have a strop handy to wipe that remaining bur off after you have finished sharpening. I like to load mine with green buffing compound. Go for either Shapton pro or naniwa pro since they are basically the same thing! Naniwa just made a shapton equivalent ceramic stone and gave it the same name. From what I hear, you can't go wrong with either. Hope this helped!
