Jereboam II specs - ???
Could someone provide the following info for the Jereboam II knife?
Blade Length - ?
Blade Thickness - ?
Blade Width - ?
Overall Length - ?
Weight - ?
I need that for statistics
I have the info for all of my one piece range blades, but Jereboam II.
zvis.com
Have Fun,
Alligator
Hmmm - The one I had went out the door, so I'll have to wait for the next one to weigh and measure it. Or CRK can probably answer this one.
- JKM
www.chaicutlery.com
AKTI Member # SA00001
Blade length: 9"
OAL: 13 3/4"
blade width: 1 7/8"
blade thickness: ~1/4"
Weight: around 18 ounces. That's a guess, based on the 14oz weight of the Project 2 which is 1 1/2" shorter and a bit narrower.
Those are the measurements of the ones I have in the store.
Hope this helps.
Dennis Wright
("Have a knife day!")
wrightknife@ixpres.com
I guess that one is what I've got
CRKT team, could you provide a little bit info here?
zvis.com
Have Fun,
Alligator
I posted weights and measures for the Shadow I in the thread with my scan of it and the other two spearpoints. The Jereboam is the same as a Shadow I, except for having a clip point instead of a spear point, so the specs should be the same, other than the spear point being a tiny bit heavier at the tip.
- JKM
www.chaicutlery.com
Just got an answer from CRK. Special thanks to Mark
Overall Length - 13.75"
Blade Length - 8.75"
Blade Thickness - .262"
Blade Width - 1.414"
Weight - 17oz.
zvis.com
Have Fun,
Alligator
