The blades come from #8/0 which is like a hair,to #14 which is almost too coarse to cut wood with.For guards and such #0,#1,and #2 is about right.Lube the blade,Make sure the tension is tight,and make slow even strokes.Don't "saw" back and forth.Lift the blade from the metal on the back (non cutting) stroke.BTW,The blade goes in with the teeth downward,so it cuts on the down stroke (opposite of a hacksaw).Jewelers blades from a jewelery supplier will cut any normal guard material.Hobby shop blades and scroll saw blades are often tempered for wood cutting.Brass,silver ,and nickel will all clog the saw teeth if you aren't sawing properly.They don't "dull" the blade,they fill the teeth notches.The enemy of jewelers blades is sawing too fast.The friction heat destroys the temper and the blade stops cutting of snaps.
