Jig Sharpening January and Free Hand February
me2
Just seeing who'd be interested in finishing January sharpening only with some sort of guided method, then converting over to free hand for February. A lot of January is gone, but l just thought of it tonight.
Not sure exactly what you mean.
I do both every month.
I was just touching up my Buck 110 with my Spyderco Ultra Fine triangle rod and probably this Sunday I will be doing a more through job on it with my Edge Pro. The edge has two little dings.
Had this 110 since '81; most of the last twenty years it has set on my dresser while I carried all manner of new fangled thing. Always modding handles and wishing for . . . something . . .
After EDCing the old dude this last week . . . maybe what I been wishing for is that the new fangled things were more like the 110 . . . handle wise anyway.
No don't ask me to do major sharpening free hand only for a month . That would suck.
Some people only sharpen freehand, other only use some form of guided method. Its just an attempt to get people out of their comfort zone.
I mostly use guided methods, but i have a couple knives that are freehand. It will be nice to see a nice more even bevel of known angle and see how far of l am from what l think. Also, it'll be interesting to see if I can get knives sharper with one vs the other, and I figure l need a couple weeks practice at least with each to tell.
And yes, you should definitely try rebeveling or other major sharpening free hand if you've not done it in a while. That's for next month though.
I've had a lansky 5 diamond grit for several years. It's not been used much. The only thing I find it can do a little better than my freehand is flat bevels and even/consistant angle. There's nothing fast, or versatile about it.
I use a DMT Aligner clamp, some guide blocks, and a Sharpmaker. I also freehand when the mood strikes. Some people are adamantly against one or the other. I didn't realize what I was missing until I tried the Aligner clamp with a Norton bench stone. Now l am able to get almost as sharp by hand, but it's a bit faster.
Ok this is january
angle wedges/ramps made by folding/taping junkmail cardboard / postcard,
put sharpening stone on it and hold knife horzontally,
thats one stone no spin sharpmaker :)
also in upper right corner ,
a piece of cardboard bent/taped to the spine,
it started off without tape,
same as angle clamp,
make sharpening cheap/easy,
just measure the width of your blade with a ruler,
then punch that plus angle into triangle-calculator (or use 1:60 rule)
then you cut a square of paper and tape it to the spine
yeah yeah I know, if you gotta type up a description the pictures could be improved :)
but it only took me 3-4 years to try this version :D
