I will just add that I have used lots of checkering files. My favorite are 20 LPI and 30 LPI. They are great for checkering and Florentine work. They are not very good for jimping. Jimping done with one would be just a group of shallow lines. If all you wanted was a slight non-skid area, then it would work. If the jimping is desired to be more than a few thousandths deep, mark the lines with a sharpie and use a tri-corner file to cut them in.
Making multiple passes with a checkering file usually ends up in a mess. The lines rarely align very well, which makes more lines than planned. In doing Florentine surfaces, that is OK, on a spine where you want even lines, it isn't.
Coining is far better done with a coining wheel, followed up by hand filing. Most machinists are familiar with these wheels. I am sure any industrial supplier of lathe and milling tools carries them. When I do coining, I just mark the lines with a sharpie and do them by hand with a tri-corner file.
Tip - use fine files, #2 cut makes nice crisp lines. #4 is even better for coining and doing file work in brass/nickel/silver/gold. #6 leaves a surface like 400 grit paper. You can use an 0 file for the beginning cuts, then switch to a finer file get the final depth and shape. If all you have ever used is the coarse #00 files in the online kits, you can't believe how smooth the surface is with a #4 file.
Tip #2 - to make even marks to file on a spine or bolster spacer, start by making two marks. ON the spine it would be the ends of the pattern. On a spacer, it would be at opposite sides of the diameter line. Next, make marks half way between those marks, and then make marks between those, etc, until it is as fine as you want. The spacing will stay pretty even this way. This makes spine lines of 2/3/5/9/17/33. Spacers ( circles) will have marks of 2/4/8/16/32. I use a fine tip sharpie to make the marks. If I don't like it, I take it off with a little alcohol, and start again.
I don't think checkering files are made lower than 20 LPI. To get an understanding of what a 20 LPI files is, look at a bastard file and count the teeth in one inch. It is probably around 20.
