- Jul 12, 2008
OK, well this is my review of Johns Bushcrafter. I am familiar with this model from babysitting bearthedogs Buschcrafter while he was out of the country, so I knew what to expect as far as fit, finish, and how it felt in the hand. Let me just say that all of those qualities are perfect in this knife. I personally find the handle shape and contour to be one of the most comfortable handles I have ever used on a knife. The handle is thick, but not too thick, just enough to get a really strong grip on it without being uncomfortable. Holding it in different positions was not a problem either as the contouring made choking up on the blade nice and comfortable too. The tulip wood scales not only look great but seemed to hold up pretty well to the few times they hit or got a little too close to the wood while I was battoning, they really showed no signs of wear. I was very anxious to play with this knife, as I did babysit one, I did not really use it.
It came to be pretty dang sharp (thanks udtjim) and was shaving hair without even trying. I was quite happy about that as I am not that great at sharpening convexed edges yet, and it was a great starting point for some rough use. I started right off with battoning through a small piece of wood (old branches from the firewood pile). A few whacks and it was right through it no problem at all. So I went right for a much larger piece of wood, one that was almost as big around as the blade is long. I beat the hell out of the knife trying to get it through. The combination of only having about ¾ of the blade sticking out and me not want to get a bigger blister on my hand convinced me to give up on that and try cross battoning through the middle. I pretty much treated it as an axe cut and pounded the blade in at an angle to get nice big chunk out, which worked fantastic! The edge on this blade just bit right into the wood and very cleanly chopped out large chunks each time I pounded it in. I tuned the wood around so I was working the wood all the way around and not long after I started, crack . Cut right through the center of that piece of wood. I tested the blade on my arm, and sure enough still shaving sharp! Shaving was not as effortless as it was out of the box, but it still shaved with little problem at all.
Next I tried battoning through another rather large piece, this one was definitely too large for easily batton through, even less of the blade sticking out the other side, but I want to try it anyway. I pounded and pounded and pounded and could not get that blade much deeper than that edge of the wood. I really beat the hell out of the knife at this point. I missed a few time and smacked the handle too. Neither the spine of the blade or the handle showed any signs of my aggression, I was very pleased with that. Not being able to batton any further I pulled the knife out and carved down a piece of the smaller wood I had split into a kind of wedge. I stuck the wedge in the small section I did batton through and then pouned the wedge right through. Cant use the knife directly to solve the problem use it indirectly to make a tool! Now I see why I was having such a rough time, a wicked knotty section in the wood.
more.....
more.....
