JK Knives Viktim
JK Knives Viktim (Hunter) Review & Torture Test - Part One
attachment.php
Introduction
John Kiedaisch is the custom knife maker behind JK Handmade Knives. He moderates a subforum on BladeForums here and you can find him on the web here. John was generous enough to offer one of his knives as a pass around here and to take it one step further by asking participants to “torture test” the knife. Andy (mqqn) is running the pass around and explains:
“The idea of the pass around is that we will put the knife through the paces of a hard use knife to test the ruggedness of the knife. We won't be trying to purposely break the knife, no bending in vices etc., but you can do anything with the knife that one might find need to do with a knife. “
Knife Specs
As a knife made to showcase the rugged reliability of his knives, JK says the "Viktim" isn’t finished to his normal standards; it was built to be abused. It is a reworked version of JK’s Hunter model (similar to a Kephart, with a slightly clipped point.) I’m told that it started as a piece of O-1 steel scrap that John pulled out of his bin and finished off to 60.7 Rockwell Hardness (as measured by Andy.) The O-1 alloy is designated as a "tool" steel and known for its hardness, abrasion resistance, and ability to hold a cutting edge. The "O" designation indicates that the steel is oil hardened. All you closet metallurgists can read more about O-1 here.
Blade
The Viktim's blade is 4.9” long, 1.44” wide at its widest point, and .11” thick. It weighs 7.1 ounces and the included leather sheath weighs another 3.1 ounces. The full-tang handle is is 4.54” long and .92” wide at its widest point. For me, the blade is the best part of the Viktim. In keeping with its Hunter/Skinner origins, the flat ground and convex edged blade cuts like a smaller, thinner knife. Maybe it has to do with what looks like micro serrations, but the Viktim is one of the best slicing fixed blades I've ever handled.
attachment.php
Handle
The Viktim has contoured scales handmade from oak and secured by two pins. Whatever lacquer or varnish was applied to the wood, it was done with a light touch. You can feel the woodgrain, making the handle a little grippier than most. Handle feel is a personal preference, but the Viktim handle didn't fit my XL hands. For me, it is too thick around the middle where it swells and I'd like to see a more pronounced guard and pommel. The great thing about working with a custom knife maker like JK, though, is that you can ask him to change it for you.
Sheath
The leather slip-in sheath provided with the Viktim looks handmade from thick fold-over leather. One clever touch is a drainage hole at the bottom. Overall, the sheath matched the knife: well-made, tough, and durable, but not terribly elegant - more Ford F150 than Cadillac Escalade. It didn't come with any kind of retention system, either to hold the sheath on a belt, or to hold the knife in the sheath. The knife doesn't fit tightly, so if you turn over the sheath, the knife falls right out. Again, I'm sure you could have JK add a belt loop or retention strap.
attachment.php
Test #1 - The Ginsu Challenge
The pass around instructions were to “do anything with the knife you can think of that you might use a knife for, except for purposely breaking it,” such as batoning, chopping a brick, or shooting the edge with a firearm. So naturally, I tackled a tomato. The results were surprising. Having attempted to slice tomatoes with other hard use knives, I expected the Viktim to crush more than cut, but it handled like a large Chef’s knife. Slicing was easy. I did note, however, that a patina started to form on the blade almost immediately. Though corrosion resistant, O-1 carbon steel isn't considered stainless.
Before I went on to torture testing, I also cut a branch from a Drake Elm. I found that the Viktim wasn't my favorite chopper. It was a little too light and and a bit too short for me in both the blade and handle. In whittling the elm, however, the Viktim really shined. Stripping the bark and shearing off wood was as effortless as peeling a carrot. Shearing the corners off copy paper was also pretty easy for a 5" fixed blade.
attachment.php
Test #2 - Tough as Nails
It is said that a US Marine eats nails for breakfast and asks for seconds. I thought I’d see if the Viktim was up to that task, as well. My next test was to hammer a finish nail into 3/4" plywood using the spine and flats of the Viktim's blade and to then chop the nail with the edge. I wasn't successful in chopping all the way through the nail because the impact pulled it out of the wood. The nail was damaged and the blade edge rolled over slightly where it impacted. I expected much more damage to the Viktim, but it held up well. The bottom photo also shows some of the patina forming on the blade.
attachment.php
Test #3 - Screw You
After the finish nail, I decided to try cutting a #8 wood screw driven into the same 3/4" plywood. It only took two swings of the Viktim to cleave the screw in two. The blade edge nicked and rolled, but again, there was less damage than I expected. I also tried using the tip of the screwdriver to turn the screw, but it didn't fit well enough to provide a real test.
attachment.php
More tests follow in Part Two...
JK Knives Viktim Review & Torture Test - Part Two
Test #4 - She's a Brick House
Next, it was time to chop a brick in half with the Viktim. Why? I can’t imagine really needing to do this with a knife, but since it was part of the program, I put it to work on a 8" x 4" x 2" concrete masonry brick weighing 4 pounds. I had my 17 year old son take a few swings downward with the butt of the knife to see if he could break the brick. It didn't do much to the brick, but abraded the wood of the pommel. Then, using the blade edge, he chipped away at the masonry. After ten minutes or so, he had worn a groove a third of the way through the brick, but it was still intact.
attachment.php
I took over with the goal of using more force and breaking the brick "Karate-chop" style. It took three or four swings to break the brick in half with sparks flying. When finished, the Viktim was intact with surprisingly little damage to the blade, although the keen edge was gone. After cleaning it up and using a butcher's steel, I could saw through a tomato, but it wasn't easy. Strokes on coarse SharpMaker stones improved the edge only slightly. I think JK or someone else with good stones, wheels, or a belt sander could restore the edge quickly though.
attachment.php
Test #5 - Car Crash
My final torture test for the Viktim was to run over it with my 4,100 pound sedan. In fact, I ran it over three times: first the handle, then the blade, then the blade and handle. I was worried about breaking the blade (and popping my tire) but the blade never seemed to be in danger. The only damage to the Viktim was some slight marring to the blade finish, some abrading to the oak handles, and one of the handle pins being driven a little lower on one side and a little higher on the other. The pins were flush with the handles before; now one stands a bit "proud" on one side. I think a few taps with a ball peen hammer would fix it.
attachment.php
attachment.php
Conclusions
The Viktim is a fairly utilitarian knife; no jimping, no colored liners, no hollow or mosaic pins, and no lanyard hole (although you could have JK add them.) It has a throwback or vintage look. You can picture it hanging from Jeremiah Johnson or Daniel Boone's belt. My wife’s comment when it came out of the box was that it looked like a kitchen knife and I would have to agree. The Viktim is closer to something like an Old Hickory or a Mora than a Randall and closer to a Becker than a Busse. JK’s available micarta options could jazz things up, though.
I've had fun with my "tests," but they've been nothing approaching the scientific. I can't really compare the pass around knife to other brands and models without doing the same to them, but frankly, I wouldn't try. I can tell you, however, that the JK Viktim seems like a tougher knife than its weight and spine thickness would indicate. It is more than tough enough for all of my imaginable needs.
I don’t know Mr. Kiedaisch, but from his forum posts, he seems like a positive contributor to the community and a great knife maker to work with. I would strongly consider him when having a knife custom made. My thanks to him for making his knife available to torture test; I'm not aware of any other makers who would do this. Thanks also to Andy (mqqn) for coordinating the passaround, and to BladeForums for giving us a place to have it happen.
nice objective review, thanks. can't wait to see more. FYI, It's o1 steel like as not, JK uses it most these days, i think he used to do 1095 more in the past.
Great review seeing as I live about 20 mins from the maker of this fine blade, I'm definately going to ask him if I could meet with him and draw something up one day:D that would truly be awesome
The brick chopping made me cringe. I know the knife is tough as nails (or tougher!), but darn it all, I sweated after the brick part. Lol. Thanks for sharing!
It would be my pleasure! A group of us get together on a regular basis. lava_lamp, I hope you are enjoying your time with this knife, I`ve enjoyed reading about your testing.
Yep. Me, too. I had to swallow hard. After years of telling my wife and kids what we use a knife for and what we don't they found it pretty weird to see us chopping a brick. But as Rocky Balboa said: "A man's got to do what he's got to do."
Hi laval_lamp -
Awesome "tests"!
I was afraid you were going to pop a tire on the run-over after we discussed that. Thanks for the GREAT pictures of your abuse, and thanks for the great, comprehensive review of the viKtim!
You have set the bar very high for the following testers!
best regards
mqqn
I'm not worthy!
not real sure how to top that testing, but I'll definitely be giving it some thought!
I agree. great testing sir. I am really looking forward to getting the knife and beating on it. though now I definitely have to step up my game for sure.
