- Jun 4, 2010
Very quick initial writeup for the diamond stone 1k/6k set offered by JKI. Have been looking at these off and on for a few years but never wanted to drop the coin. Came into a little mad money, picked up the pair. There is not a lot of info circulating re these stones, thought I'd share what I know so far.
Am not a big fan of the bonded diamond abrasives I have tried, so this was a leap of faith for me. Haven't had them very long, this is also a very preliminary review.
Initial impressions are that on budget stainless these are somewhat slow cutting compared to ceramic stones of comparable grit. Cut speed of the 1k is closer to that of a 2k maybe and the 6k that of a 10k ceramic. If applying a microbevel with the 6k you don't have to worry about removing too much steel too quickly.
Grind finish looks typical for the rated size.
Edge quality is very good coming off the 6k, still has bite. Used on an O2 chisel and stropped with some of my house Washboard compund it was shaving endgran pine to a nice wet finish. Not good enough for real fine finish work but plenty good enough for most chisel work - whittling armhair off the surface.
The stand alone edge off the 1k is maybe perfect for an EDU blade. Sharpened up a Vic utility knife and CS minituff in Aus8, with a handful of passes off a washboard charged with mud and swarf from the stone surface, treetopping leg hair with authority yet wicked catchy.
The bond material has enough "give" that both stones will just tolerate a backhone pass to finish. The surface is just hard enough that this is not necessary to get the best from the stone - so a bit of flexibility depending on preferences. I prefer to finish backhone if the stone will allow as it seems to make an edge that is that little bit more catchy.
The surface does not load much if at all as long as it is kept wet - actually better in this respect than some of my ceramic waterstones, needing only a little agitation with a fingertip to release the swarf. This is a major beef I have with a lot of the bonded diamond stones, so am very pleased in this regard. It is easy to keep the surface wet, and the composition does absorb a bit of the water - completely dry in under an hour if the surface is squeegied with the edge of your hand when done.
Wear appears to be negligible, but have not used them enough to get a feel for this. Using the suppled Nagura stone, a very thin tea (not mud) the color of the stone can be raised with a bit of rubbing. A bit of color also visible on the reclaimed swarf from the stone surface after several minutes of spirited grinding, though most of that is just swarf. Am going to use Barkeeper's Friend on the surface to unload it next time it is needed - surface reconditioning with an abrasive really should not be necessary, although it is recommended for best results, so loading and/or glazing must be a genuine factor over time.
I haven't used them on high carbide steel yet, but will do so in the coming days/weeks. I expect they will perform even better on the higher RC/high carbide steels. My hope in getting this set was to have stones that could perform well on ANY steel, travel well, last nearly forever, and be more user friendly and durable than diamond plates. So for now am concentrating on budget steels. The 1k is not aggressive enough to reset bevels if the edge has any appreciable wear, a coarse stone is definitely needed to complete this set, but at that grit level any SiC stone could easily stand in. The 1k can overgrind a fairly aggressive scratch, so an intermediate stone isn't needed. If a mirror finish is needed, some form of finishing stone, strop, lapping film will be a must. It is a true 6k finish, for most chores this will be more than refined enough, and on high RC/carbide steels I expect the scratch to be even less deep. A bright finish, but not mirror by any means.
So far cannot give an open-ended recommendation as I just haven't used them enough for the price. If they were less expensive by half it would be an easier call. That said, if you are already a fan of bonded diamond abrasives, these are worth a closer look. While a bit slow on budget stainless compared to some ceramic stones, they have very good feedback for stones of this type, make a very good quality edge with minimal fuss in terms of burring, both from abrasion and pressure, and hardly load in use. They manhandled the O2 1.5" chisel, which was another pleasant surprise and more testimonial to how little they load - with short work, the tea on the surface of the 1k was swimming with swarf. The 6k overground the entire bevel in under a minute.
I have had them less than a week. Stones are roughly 3"x8", splash and go. They come with a robust rubber base and nagura stone. More to come.
6k side view
1k side
washboard slush
6k side view
1k side
washboard slush
