Bug,
Your original post made me realize that I had never sharpened my La Griffe. So, I went the same route as you, only I didn't have any problems raising a bur. I used the grey stones on the 204 and tilted the blade to the right, so that I was hitting the entire primary bevel on the left side of the blade. I didn't notice any difference in angle near the tip.
After a couple of strokes, I noticed a huge bur on the right side of the blade.  Stropping would not even touch it, so I carefully ran it down the grey stone to remove it from the right side, just barely raising the spine of the blade to prevent scratching the black coating.  What happens?  The bur moves back over!  I had never seen this kind of behavior in a properly hardened blade before.
Moving to the white stones and applying gentle pressure, I was able to grind off the bur and prevent it from merely swinging to the other side.  Some light stropping and I had a very sharp edge. BTW, I made a strop from a 2X12" piece of leather glued to a 1.5" dowel. Works great.
Anyway, back to the edge.  From what I can gather, the edge was sort of ground convex, leaving a sharp but very thin/weak edge. That might explain the behavior of the bur. I guess it's just that it's a different edge geometry than I'm used to dealing with. It doesn't appear to be heat-treated poorly, because some tests in cardboard showed decent edge-holding. I know that my method resulted in a slightly steeper angle, but it's repeatable and it worked for me. If I had to remove a lot of steel to restore a very dull edge, I might approach this differently.
What sort of compound are you loading your strop with?  I'm using this stuff I found at Woodcraft that comes in a pink cake.  You have to scrape some off to get a powder and then spread it into your strop.  Marketed for woodworkers to use for honing plane blades, gouges, etc.  Works well, but moves around the strop a little too much and doesn't like to stick in the rough side of the leather.  I'm thinking that a grease-based compound like a chromium-oxide (is that the green stuff?) might work better for me.
[This message has been edited by Greg Melcer (edited 01-03-2001).]
