Today I rigged myself a quick thread cutting tester. THIS IS NOT MY DESIGN IDEA!. This is a modification based on a design that Nozh I believe showed on the forums about a year ago (found the thread, see here: http://www.bladeforums.com/forums/showthread.php?t=346429). I liked the design because tying nooses with thread drives me nuts.
But now the question becomes: What kind of thread. I would have thought it wouldn't matter much, there would be simple and offset in the numbers... but it seems that is not the case. I started with really thin poly thread and my Yojimbo got 35 g. Not constistently over the entire edge, but that was no surprise since the edge was already used. So only the part that didn't really see any use very close to the choil achieved that performance.
Still the number seemed very low. So I tested my straight razor and it clocked in at 14-18 g!!!! It actually cut the individual fibers while the other knives cut the thread in one snap.
I tested the strength of this poly thread by taking a simple 1 foot plastic ruler and pushed till it would snap. It did so at about 1.5 kg. I figured this would give a way to compare different kind of threads. So, to get more comparable numbers, I dug out some thicker poly thead. This one is labled "button/carpet" and made by singer. The strength of this thread is beyond the measurement capabilities of this setup. It will tear at the screws, not at ruler at well over 3 kg.
My Yo clocked in at about 80 g with this thread. I tested as benchmark the straight razor again and it came in at about 130 g....huh??? Ok, so I tried again...with reproduceable results.
I looked at the straight razor blade and it turned out that the stronger and thicker thread had actually cut a notch into the edge of the razor! Not very large but clearly visible with the naked eye and rather pronounced under a microscope. The edge had deformed during the test and this was why it suddenly took more force than the Yo.
Now I start to wonder: At what forces does microscopic edge deformation begin. When does this test become unreliable. It is quite clear from this little test that even the slightest burr will give very poor performance on anything but the thinnest thread....so what is the ideal thread thickness, and how do we measure it?
I will go to an arts and crafts store tomorrow and will sample some threads.
Btw. this little setup costs in total about $45 ($40 for a nice digital kitchen scale) and can be assembled in about half and hour and you can do about 6 cuts per minute. The thread is clamped between the regular nut and the wing nut.
Oh, I forgot I tried the thread with and without slack, but the difference was not very pronounced. Have to test that further though.
