Junglas IN 5160 STEEL
csabacanada
I was wondering if was possible to get a junglass in 5160 steel.i love my rat 6 and 4 ,and i really like 1095 steel and i think that is hard to beat esse knives for quality and value .i really -really like the looks of the junglass but i don't like longer knives than 7'' knives in 1095 .i had problems with them in the cold canadian winters.the strength of the 1095 is edge holding not toughness and i have seen the junglass test video ,but the hardness is at 56 rc ,that is pretty low .yes ,it is tougher but at 56 it loses a lot of edge holding but with 5160 it could have up till 58-59rc and still would be very tough.anyway ,if is not possible i will still get one but i will have the heat treat redone to higher rc and differentially heat treated.thank you .all the best
Someone always wants a different something no matter what, thats why people get customs made. It would be really hard for a knife company to just start throwing out knives in all steels and configurations. Also you really cannot expect the same edge retention from a huge knife as a small knife toughness considered.
The Junglas has the same heat treat as the rest of the line. Does the rest have enough edge retention for you?
ESEE-4: 57RC
ESEE-3: 57rc
ESEE-5: 57rc
ESEE-6: 57rc
Izula: 57rc
These are taken directly from the website. They don't specify on the website for Junglas, Lite-Machete, or AH-1. I'm sure Jeff or Shon can help with this.
I'm pretty sure that is what Shon said during the chat session...because I asked if the Junglas heat treat was any different than the rest.
Fair enough. Actually the knives are listed a few places at 57. i guess I could have investigated further instead of going on my shoddy memory. :foot:
Most machetes are upper 40s to mid 50s RC. They seem to work fine. The Junglas at 56 has better edge holding than most other machetes. I have no problem at all with Rowen's 1095. But if you want 5160, you can just get a Ranger RD9. It's a pretty darned good chopper, IMO. With so many good knives available nowadays, we can get them in many different steels, but not all from the same manufacturer. I have had very good performance with 1095 steel from Bark River, Ontario, Rowen, and others.
To be fair the Junglas isn't your typical throw away machete and it wasn't designed to be that (not at 3/16" thick and $175) A Junglas at typical machete hardness would under-perform ridiculously. I do agree with you though that Rowen's 1095 at 56 or 57 RC will give this knife the same kind of performance we've come to expect from ESEE. In a word...awesome. :cool:
If you manage to break it, ESEE will replace it no questions asked. I'm not sure what problems you are having with sub-sero temperatures and 1095.:confused: I've lived through a lot of winters and have yet to experience problems with any of my edged tools.
My point was only that softer tempered steels are used all the time for hard work and they perform fine. The only parameter in which the Junglas will out perform a full length machete is edge holding. No way a 10.5" blade will work as well as an 18" blade in clearing or chopping live wood, no matter what the steel, even INFI. For a "machete", the Junglas is tempered pretty hard, and we have seen from the destruction testing that it is amazingly tough for a blade so hard.
Yea. I've used my RTAK II to baton frozen solid maple and oak in ten degree F weather. And thats with the questionable heat treat. Also used my RC6 in that weather. I plan on using the Junglas in much the same manner. I don't forsee any problems with this plan.
My point is that you would never use steels that soft in a 10" x 3/16" blade. You need to use softer steel in machetes because they are so long and thin. There is a sacrifice in edge holding because their needs to be. The Junglas doesn't need to make this sacrifice, so it can be treated to a higher RC and stay sharper longer (as you've stated). I agree with you that a machete will out-perform a 10" blade in many respects, and I have learned that a machete is one of the most useful and versatile blades there is. For a 10" 3/16" blade the Junglas "machete" is not tempered hard at all. It is in my opinion tempered correctly (as it was designed length and thickness wise to perform as a large knife).
That's my opinion as well. I don't look at the Junglas as a machete, even though the drop down navigation on the website calls it "Junglas Machete?"
I see it as a large knife for shelter buidling, wood processing and other suitable tasks. Similar to something on the order of a Busse Bushwacker Mistress. 1095 at 57RC is right for it IMHO.
Now the "ESEE Lite Machete" is what I expect to see in a machete - in terms of OAL, 1075 steel - I couldn't find the Rockwell numbers though. :thumbup:
Whatever the numbers are, the things chop, slice, and bust up trees. I'm sold.
