- Nov 7, 2013
And it worked just fine despite the general consensus. Results were no different then any low vanadium steels and it didn't really take that much more polishing. Just figured I'd pass it on.
And what comparison are you using? Do you have other compounds? Do you know the difference diamond compounds make? How do you know "it worked just fine"?
I am not sure that I should be surprised and why "... Despite general consensus"?
I understand that the vanadium carbides in the S30V steel are about 2-4 microns large so unless your white compound has a finer abrasive, you should not see a difference compared to other steels anyway. Once you get down to 2 micron size, you would need an abrasive hard enough to "cut" vanadium carbides to uniform the bevel/apex and AlOx would not be able to do that. That is how I understand this. I might be wrong, have been before.
Vanadium carbide has a mohs hardness of 9-9.5, white aluminum oxide is slightly harder then Brown (the kind in india stones) and has a mohs hardness of greater than 9. I haven't seen anything stating how much harder than 9, just that Brown aluminum oxide is 9.0 and white is 9+. I've also heard of people using cbn on high VC with excellent results and it has a mohs hardness also of 9-9.5. Diamonds can still be scratched by other diamonds, so if the hardness is about the same wouldn't it have some effect? Also looking at SEM images of knife blades at various sharpening stages everything I've seen shows the scratches are about 1/10 the size of the abrasive, so theoretically (assuming I'm not missing something) being a few microns larger than the VC shouldn't matter?
Let it be known I'm definitely not saying that I am without a doubt proving that white rouge is capable of refining high a vanadium edge with the same effectiveness as a comparable diamond abrasive. I don't have a microscope capable of observing tiny carbides so I have no concrete proof other than it worked from a sharpening perspective the same way I'd expect it to work on typical steels, and discussing why that is interests me.
Moh's is a completely unitless scale, and essentially meaningless in such comparisons; in other words, it's a 'ranking' of softest vs. hardest, with no measure at all of the actual differences in hardness. Compare it to a track race with 10 competitors, with the 'Winner' being faster than the others, and no indication of actual finishing times.
When using a real 'hardness' scale, such as Vicker's, which defines hardness in real units of measure, vanadium carbide will be ~1/3 harder than aluminum oxide (~2100 Vickers for AlOx, versus ~2800 Vickers for vanadium carbide; CBN is ~4000-4500, and diamond at 7000).
David
A little bit of searching shows that white aluminum oxide is indeed 3000 vickers vs 2100 for brown, so back again it might actually be hard enough to have an effect assuming the data isn't incorrect.
Looking up knoop hardness even the harder white alumina is 2600, so still too soft. Guess my questions answered. Why does it not matter until you get below 1-2 um considering the scratch size of an abrasive is about 1/10 the size of the abrasive particle?
At larger sizes of abrasive grit, the 2-4µ vanadium carbides are essentially being scooped or plowed out of the softer matrix steel, as opposed to being shaped or polished in-place. When the abrasive grit gets smaller, it's no longer big enough and won't dig deeply enough to knock the carbides out, and instead will either skip over them (if less hard, like AlOx), or cut through/abrade/refine them (if hard enough, such as with CBN or diamond).
I didn't really understand what the effect was either, until seeing the difference made by the 3µ diamond I mentioned earlier. That's when it started making sense to me.
Another thing to think about: when using compound on a strop that has any 'give' at all, like leather/denim/etc., or even on wood, you're effectively handicapping your abrasive even more, making it effectively much less hard. Sort of as if the abrasive grit was applied to a soft, squishy mattress or pillow, with a lot of cushion under it. With an abrasive that's already significantly less hard than the carbides, it gives the abrasive virtually no chance to do any good on the carbides. This is why diamond or CBN work so much better on most any backing, because the abrasive is still hard enough to do some good on less-than-hard footing. This is also why a given type & size of grit will dig deeper and leave a coarser scratch pattern if used on a hard stone, as opposed to the exact same grit used on a softer substrate (paper, strop, etc), which can't dig as deep and leaves a more refined or polished finish.
David
Do you think it's going to make any real difference if one uses white compound prior to using 1 and .5µ compound on s30v or would a significant difference be noted if the white was swapped for 3µ paste? Lately I've been using the white in between my 8k norton and the 1µ diamond because the grit was just to big of a jump. I've been getting pretty good edges this way.
Denting or chipping of a hardened blade's edge by a staple is all about plastic deformation or fracture under pressure or stress - essentially meaning the steel is moved or fractured by, but not cut by, the less hard staple. The carbides in a high-wear steel, and the steel matrix hardness, will limit or prevent abrasion (cutting) of the steel by the staple, but won't do much in terms of preventing deformation or fracture by impact or lateral pressure.I mostly agree with you especially that s35vn is not especially high in vanadium. But to dent 60hrc steel, even if it is the matrix around the carbide with a staple at say 45hrc proves that things of lesser hardness do have some effect on things of higher hardness. I'm not saying waterstones are very good for steels like 10v or such but I prefer them and I won't buy knives in steels that won't sharpen well with them. As for burrs I sharpen grandpa style. You don't get much of a burr that way. And I finish with light alternating strokes, which should remove one. I finish on bare leather which is also supposed to remove a burr.
