hey guys I recently purchased an ontario rat-3 knife and a norton oil benchstone. It seems that the blade is not razer sharp so I decided to sharpen it (my first time). I have read around and the threads had told me to angle the knife until it "bites" the stone and sharpen it until it has a burr, is the burr the powdery gray stuff that comes out on the other side of the knife? or is that my stone? also it seems that after sharpening it, it still does not seem that sharp. What should I do? and the steel is 1095 not d2
I believe I use the same stone as you own.
I make knives so when I sharpen each knife that first time my knife will start out totally dull, not even a hint of sharp edge...
I hold the first side in position and only sharpen that one side.
Im not sure if I should or not, but I grind the stuffing out of that side, back and forth, never taking the blade off the stone.
I rub the edge into the stone back and forth, round and round...working the edge to grind off and nicks and junk that might be left over from when I was making the blade.
I just make sure that I keep the edge at the same angle...
Im looking for the wire to form on the top side edge.
The wire is just the steel of the very knife cutting edge that has got so thin from being sharpened that it flopped over onto the unsharpened side.
I have to keep rubbing the one side until I have a wire edge all the way along the full cutting edge.
If I dont get a wire edge Im not getting the knife sharp as it could be.
When I do, then I flip the knife blade over and do the same on this new side.
Once I have a new wire edge on the top side again, I know at that point that the knife is sharp and now I have to get rid of the wire.
This is the point where I do the more traditional sharpening where I drag the edge across the stone, flip the blade, and drag it back the other way, and flip again.. etc,etc.
I lightly feel for the wire edge with my fingers after a little while to make sure it has become rubbed off.
Then I use less force as I drag the knife across the stone...
The last few strokes are very light....
Most of the time at this point I have to get rid of the scratches from the stone so I go to the buffer....but thats only because the knife will be sold to someone else....
useing the buffer is tricky.
The buffer can really get a blade hair-popping sharp, but it can also make a blade very dull in seconds...
I had some co-workers come over to my house to learn how to sharpen and I got to see first hand the more common problems guys have with a stone.
#1, the first problem was not knowing what a wire was....They knew about the wire, but they didnt relly know what it was untill I showed them what it felt like.
#2, Another problem that had was not holding the blade at the same angle.
#3...I also noticed that they tended to stop too early,,,they didnt understand that you got to go stroking untill the wire tells you it's time to go to the next step,,,counting strokes is meaningless..
#4 in most of the books the writer tells us that to cut the wire free of the blade you raise the angle of the blade on the stone slightly.
My co-workers always would raise the blade up too high and would be just dulling the edge and needed to start all over again. That was my problem whenever I tried to use the "mouse pad" system too,
#5,,and lastly,,,the wire needs to be removed, but the trick is that if you dont actually get the wire cut free, it can fool you into thinking that the cutting edge is very sharp...only to have the wire edge fold over when you tried to use the blade
