just got 710HS & 806D2. some opinions...
I just got my first two benchmades, a 710HS and a 806D2.
710HS impressions
Smoothest opening folder I have ever held in my hands. I do not know why so many hate the thumbstuds...they are better than any other knives I've ever tried. They're small and do not jut out enough to snag anything, are smooth to avoid hurting your thumb despite many openings, and yet positioned perfectly to allow smooth opening without having to adjust your grip in any way when at the halfway point of opening
Now for the bad: the front of the handle is too large and I find that it forces my forefinger to adjust from how I normally grip knives. This in turn makes my hand grip lower than otherwise and the tapered butt end makes me feel as if I do not have a secure grip on the knife.
Secondly, the Delrin spacer is horrible in its fit. From a spine view, the fit is square and tight on the right side but on the left seems to be more rounded and shorter than the left steel liner. This makes a groove that runs all along the left side of the knife so if you were to run your finger along the spine, it does not feel uniform and smooth but misaligned. The 806 does not have this problem and the Delrin on it fits perfectly. However...
806D2 impressions
The 806 spacer has a roughed up point near the blade end of the knife. It seems the plastic was scratched and you can feel the damaged part with your hand. I do not know if I should sand it down or not. I'm concerned that it will scratch up the Delrin even more and possible the steel liner too...
The blade is almost centered but seems to touch ot almost touch the liner on one side when opening. There also seems to be a slight "wobble" during opening as if they is some slight play.
The biggest problem I have with this knife is the opening hole. It stinks. It's not a Spyderco so there is no ease of opening as the oval does not allow me to open the rest of the blade once it nears the torx screw section of the handle. The handle right above the cutout is large enough so that it prevents my thumb from going around smoothly and so many times the blade is only half opened and I have to flick it the rest of the way or try the thumb again. I would have preferred thumbstuds such as those found on the 710. With some practice I can now open it smoothly almost 100% of the time but studs would be 100% of the time...
My original purpose was to find a good EDC for defense. However the 806 is too large to carry in urban environments not to mention that I cannot open it smoothly, and the 710's narrow end does not make me feel comfortable using it in a defensive role. Therefore both knives have very good yet also very bad qualities that work against them in a defensive role for me.
Well fair enough curious, nice review.
I expect you know this - there is a separate Review forum of course. The distinction isn't altogether clear though I must admit.
As I've said before, I much prefer the 710, for the reasons you mention plus some others. I'm with you on the thumbstuds. My 710's liners look fine to me and am not sure what you mean about the grip adjustment - might be a personal thing.
i never really use the studs/hole to open my axis stuff, ya just manipulate the button/flick your wrist to open/close, easier/faster than the stud/hole imho.
i would think the 806 would be an excellent SD blade, i used to carry mine all the time and i love the handle shape, and it carries well in the pocket. but hey to each his own.
good luck,
greg
actually a funny thing happened after a few hours of playing with the 710 and 806...
they started to really grow on me more!
the 806 especially...it felt just right in my hand, in any grip. The hole ended up being smoother to use than the studs of the 710. If only it didn't stick so much...
the 806 does seem better and better for a SD knife but the problem is the long handle size and the inch or so protruding at the butt end. Most likely I'll carry the 710 more in warm weather b/c it's easier to conceal and save the 806 for winter and jacket pockets :)
Haven't tried yet but I think the hole would be easier to open with gloves on and impossible with the studs
I can flick open the 806 but it seems to me that opening that way is in fact slower and more cumbersome. The 710 I cannot get a good enough hold on it to flick out without either blocking the blade or not gripping back the AXIS bar enough
