Just got a new book: The Science and Engineering of Cutting
I ordered the international version on Valore Books to save on those crazy textbook prices. It's 407 pages, with 31 pages of cited references. Here's the chapter titles.
1 Controlled and uncontrolled separation of Parts: cutting, scraping, and spreading
2 Fracture mechanics and friction: muscles, impact, and new surfaces
3 Simple orthogonal cutting of floppy, brittle, and ductile materials
4 Types of chip: load fluctuations, scaling, and deformation transitions
5 Slice-push ratio: oblique cutting and curved blades, scissors, guillotining and drilling
6 Cutting with more than one edge: scratching, grinding, abrasive wear, engraving and sculpting
7 Sawing, chisels and files
8 Punching holes: piercing and perforating, arms and armor
9 Sharpness and bluntness: absolute or relative? Tool materials and tool wear
10 Unrestrained and restrained workpieces: dynamic cutting
11 Cutting in biology, paleontology and medicine
12 Food and food-cutting devices and wire cutting
13 Teeth as cutting tools
14 Burrowing in soils, digging and ploughing
15 Unintentional and accidental cutting: supermarket plastic bags, flling objects, ships hitting rocks and aeroplanes hitting buildings
As you can see, it covers quite a few topics on cutting/matter separation and shaping. Should be useful in interpreting results of tests and sharpening.
Sounds like an interesting book! I've been looking for a definitive read on blade and edge geometry effects, that's covered [well?] in there i'm sure.
Also wondered where exactly the line is between cutting and abrading.
How is it illustrated?
hardhart,
Sweet! Thanks for the heads-up. I'm putting the book you mentioned into my list! :)
It's on amazon.com, and you can "Look Inside" for limited browsing (contents and some content) before deciding to buy.
http://www.amazon.com/The-Science-Engineering-Cutting-Biomaterials/dp/075068531X/ref=lh_ni_t
Sincerely,
--Lagrangian
P.S. I wish I could afford these books:
_Tribology of Abrasive Machining Processes_
http://www.amazon.com/Tribology-Abr...4905/ref=sr_1_1?ie=UTF8&qid=1335979913&sr=8-1
_Handbook of Lapping and Polishing_
http://www.amazon.com/Polishing-Man...=sr_1_2?s=books&ie=UTF8&qid=1335979942&sr=1-2
_Handbook of Machining with Grinding Wheels_
http://www.amazon.com/Machining-Man...=sr_1_1?s=books&ie=UTF8&qid=1335979942&sr=1-1
P.P.S. In the meantime, here are some microscope videos of metal being cut, as well as some lectures on metallurgy:
Microscope video of cast iron being machined:
https://www.youtube.com/watch?v=XZh6WGR16q0
A few different steels for the workpiece (mild steel, etc.), 30 Degree Rake Angle High Speed Steel
"Slow motion of what happens in the cut. Different coatings, different materials."
https://www.youtube.com/watch?v=mRuSYQ5Npek&feature=BFa&list=FLles5SBnY2MP8RwytEAsitQ
"This old movie shows a magnified (~100x) moving image of machining steel with a zero lead angle about a +30° rake angle and about 5° relief (clearance) angle and formation of a BUE (Built up edge). It also has a cartoon showing how the BUE formation damages the finished machine surface."
https://www.youtube.com/watch?v=-Tf...DvjVQa1PpcFN8IeIXg9wYBIcVnT4jZO2dRm-KIwpN76w=
Video of martensite transformation in steel.
https://www.youtube.com/watch?v=OQ5...DvjVQa1PpcFOFwjqw2BNOW4L5b3kOBOvbOtFf5IAkvLE=
And a educational tutorial that simulates grains and dislocations using solder-balls between two glass plates, which are "annealed" by vibrations from an ultrasonic speaker:
https://www.youtube.com/watch?v=oBb...DvjVQa1PpcFN8IeIXg9wYBOxogYKZhfD8e6H3q7hiBUk=
Here are some Metallurgy lectures presented by Professor H. K. D. H. Bhadeshia at the University of Cambridge:
https://www.youtube.com/user/bhadeshia123/videos?view=1
I was so intrigued by the description of the book I bought the last international copy on alibris moments after reading the first post.
I bought my copy from amazon.com. I noticed that amazon had two in stock. But after I bought mine, there were none left in stock! Looks like someone else bought one at almost the same time. Now it says,"Usually ships within 1 to 3 weeks." You can still get it from Amazon.com, but it will be sold from one of the other sellers at Amazon.com, rather than Amazon.com itself.
