- Jun 17, 2006
and reprofiled a carbon V SRK using the 15 degree back bevel and finished the edge with a 20 degree microbevel. I then proceeded to accidently slice the end of my finger, barely even felt it- this thing is great! I have never been able to produce a quality edge like this so quickly; I am not to the level of what you guys classify as scary sharp, but it is a definite improvement over past efforts. Next up will be using Joe Talmadge's technique for sharpening a 710 d2- is there anything in particular I need to keep in mind in sharpening d2 steel? I will likely use the same technique to sharpen a Ti Bump.
To avoid rounding the tip off the SRK, I did try something a bit different- I put the tip on the flat of the stone and pushed it down and away, rotating the knife handle downward to keep the edge as perpendicular to the stone as possible. I only did this on the tip of the SRK, but it seemed to work. With smaller, shorter blades such as the Leek, it wasn't really necessary.
