Just got back from an Auction... Anvil ID help?
Today, my dad an I went to an auction that listed that they would have an anvil for sale and other tools. We showed up, found the anvil, and by my rough guessing (trying to pick it up from the table it was on) it was a little over 100 lbs. I felt a little bit of rebound with a small socket that was next to it, but without having used an anvil before, I didn't know how good it was.
Well, when it was up for bids, it was between me and another man. The bidding started, and it ended at $80 for me. After the purchase, the man I bid against and a man who used to collect anvils were discussing the weight. I said "When I tried to lift it up, I guessed it was a little over 100 lbs" but both of them were positive it was around 80 pounds (+/- 5 lbs). So I start getting a little concerned about whether or not $80 was a good deal for it. When my dad and I were ready to leave, I carried the anvil from the backyard of the auction place to the street, about 1/8 of a mile. I was convinced that it was 80 pounds, so there was no way I would get myself to put it down and take a break 2guns So after we get home, I grabbed a bathroom scale, put the anvil on, and it reads 124.0 lbs.
I do not know what the make of the anvil is, but it has very good rebound (my guess is around 75% with a ball peen hammer), so I think it was a pretty good deal.
So here's a few pictures of the anvil. Does anyone know what the make is? It's about a 124 or 125 lb.
Full anvil shot:
Close up of the logo? It looks like it says J.W on the left, and DUP?EY underneath the blocked X
On the other side, there are two letters that look like "K" made out of dots.
I also picked up a draw knife for $2, that could help with making bows.
Oh, and there's also a square hole, around an inch or so deep, in the side under the horn, the side opposite that, and in the center of the bottom.
And I found what appears to be two numbers on the side with the "K" The numbers appear to be a "1" on the left side, and a "14" on the right.
Mark, I think you're right with it saying DUDLEY. And I think you're right about John Wilkinson too.
I found a picture of an John Wilkinson anvil from Queen's Dudley, and it has the same JW and the X.
The numbers are likely the weight of the anvil in the hundredweight system. There are usually three numbers. The number on the left the number of full hundredweights (112 lbs), and is 1 which equals 112lbs, no number in the center which would be quarter hundredweights (28 lbs), then the number on the right is 14 which equals 14 lbs. Total = 126 lbs.
Sounds like you got a sweet score. Congrats.
-Mike
-Mike
That sounds about right. The bathroom scale said 124 lbs, so 126 is pretty close.
Nice score! When I was a lad my grandfather taught me how to make an ax handle out of a hunk of ash using a draw knife (of course, this was AFTER I had broken the original handle).
I figured $2 is a steal for one of those, and I can use it in bow making easily. It seems to be good quality.
Great Score Mike!
Now I just need to learn how to use it! :o I'll be building a small firebrick forge soon and hopefully I can start forging a few pieces out on it.
Mike, the holes under the horn and under the heel on the waist are holes used for porter bars for handling the anvil while they were making it, you only get this on forged anvils.
Is it being forged a good thing? Does it mean that it has a hard surface plate that was welded on, and a softer body?
Just looked up my Anvil That I've had for a Few years. A buddy of mine in Madison Wis Gave it to Me! The Back half Has been Broken off. All Of a sudden last night I seen some Markings on it and Decided to Try and find out some info on it! I've never seen an anvil broke like this . I'm Glad to See I'm not the only one that has one of these animals ! I sure would like to have more info if anyone comes up with something ! Thanks Al
That's a Wilkinson anvil, and one of the best brands you could ask for. I have one that same size and it's a dream to work on.
The body is forged out of wrought iron and has a tool steel face plate welded on top. The thickness of the face plate isn't much, so don't go crazy with a grinder hoping to make it perfectly flat. All of the older anvils were forged, usually being welded up from smaller sections, and then had the face plate forge-welded on.
It will ring like a bell when you hammer on it. The best way to get rid of this without any fuss is to simply apply some silicone caulk between the anvil and the stump. Shuts the anvil up real quick and makes working on it far more enjoyable.
