Originally posted by crowinghorse
Yes, I have carried the Brend in a kydex sheath. I have just returned to the USS Tarawa after spending a few months on shore.
I might as well post my review of the Brend now since someone you ask:
The Brend Fighting Hatchet is simple tool. It can cut, puncture, and pry as well as any hatchet or axe I have used. (I have yet to use a Next Gen tomahawk, however.) I originally received the hatchet dull and a little misformed due to the laser cutting on the first production run. Using a grinding wheel, I rounded off the pointed edges, and rounded off the pommel so it would not stick me. I sharpened up the edge of the hatchet to shaving sharp and modified the bottom of the hatchet so it could be used as a hooking edge.
I carried the hatchet in a modified kydex sheath made by Survival Sheaths. I had it in the under arm carry mode, however, this was way too hard to access due to all the gear we carry and wear. Using a web belt, I made a baldric type sheath instead. I just threw this on over the top of all of my gear and it worked perfect. It is an excellent mode of transperation and easily accessable.
The blade performed better than I could have imagined. Everywhere I went, the blade went with me and and did everything I needed. I punched holes in tires, ammo cans, and boards with no problems. (The tires on the jeep tires took about 4 good strikes to puncture).
I used the hatchet edge to break locks (quite a few took more than one good crack!)
Overall, I could have asked for no better tool to carry while I was in Iraq. The hatchet, used with a multitool, took care of every knife need I had. I didn't even bring a fixed blade on this deployment.
If you need any more help let me know. I have only ever carried two types of blades: Busse and American Tomahawk. Back when Mr. Prisco sold Busse, I bought my first and I just followed Mr. Prisco over to ATC. I just commisioned a custom hatchet/lance from ATC and Mr. Gingrich is currently working on it. ATC backs, not only their products, but their customers too. I am a loyal user and fan.
Sgt. Jess C. Horsley
BLT 2/1
USMC
On my way back to the States...
