- May 3, 2001
I just received my first Sebenza. It's a small plain one with a stone washed blade and I plan it to be my everyday carry knife.
I'm a mechanical engineer with aerospace experience and all I could think of when I saw the knife was "aircraft quality".
The fit and finish live up to the myth. The lock up is suberb and the bar covers about 70% on mine.
It is extremly sharp and a tool I'm sure will be with me for a long time.
I do have two minor critcisms (constructive) and one suggestion.
First, the thumbstud should be ambidextrous. While I open knives right handed 90% of the time there are times when I must open it left handed. Yes, I know you can do it with the left index finger but it's not as effective and not as safe.
Second, I find the thumbstud a bit on the small side and mine has rather a sharp edge on the top groove. Maybe my thumb is a bit too sensitive but then it's my thumb and I am the customer. I could probably fix it with some emery cloth but that would destroy that beautiful blue finish and make for small slick thumbstud.
An immediate suggestion came to mind for dressing up the Sebenza which I'm sure some one will go after if Chris doesn't. Come up with some fancy screw heads similar to the designs that are often found on expensive guns. Ones I've seen that are attractive include star and flower designs. These could be an option on a new knife and a retrofit kit for the rest. Chris if you use this idea, I expect the first set to ship to me.
This is without a doubt the best folder I've ever had and I'm sure I will be after a large Sebenza when I have the funds.
Thanks to all you Sebenzanistas for making it easier to spend my money in confidence.
Malcolm
To know is to know that you don't know.
Malcolm
