Just how goofy-floppy is this backspring?
t1mpani
Platinum Member
So yes, the classic problem with (it seems to me) Queen's pocketknives: their seeming unwillingness to design a proper kick, and resultant dull/dented spot in the edge from it contacting the backspring during closing. I say unwillingness and not inability because I have a Canoe from them which doesn't have this problem, though perhaps it was a mistake. I suppose it's possible I've just been extraordinarily lucky over the years, but I've never met a Case, Buck, Boker or Bulldog that's done this. And no, I'm not a Queen-hater, I have several of them, and love the bloody things, but it's a very consistent flaw.
Anyway, I bought a Two blade Gunstock from a local dealer a few days back, as I've just always had a soft spot for that pattern. I knew before I took it home because I could already see a bit of indentation, but I just said screw it, I'll have to reprofile the thing anyway (as it had Queen's typical butter-knife factory edge), so I'd just remove a little blade height to give the kick more room to do its job. That's worked just fine in the past, and usually it would take a VERY trained eye to know that anything has been done to them when I'm through. So, I started grinding. Yes, I know this will make some cringe, but I'm good at it, and D2's temperatures run so high that occasional dunking is all that's required. So, grind a little off, coat the edge in black marker, close it. Still hitting. Grind a little more off. Check. Still hitting. Crap. Grind MORE off--the blade is now slightly more than 1/16" narrower than it was when I started, but the cross section of the newly squared "edge" is so thick now that closing it will not show any damage even to the black marker, so I put a new bevel on, few passes on the loaded leather belt to get it sending hairs flying, and pop it closed again. Dent. Son of a bitch-in-heat, just how much flexibility does this backspring have?! I mean, I removed a LOT of material--normal sharpening (especially of D2) would take a LOT of normal use/sharpening to grind away that much steel. Not that I'm going to, but I really wonder just how far I'd have to go before the thing doesn't beat itself up in the handle that's supposed to be protecting it. I checked, and no the edge is not riding on the backspring when closed, it's only with momentum that it makes contact.
Yes, yes...I've heard it, you're not supposed to snap your knives closed. You're entitled to your opinion. I say that's a load of crap. My grandfather taught me to close my first slipjoint against my leg when I was five years old. Not only does this keep your fingers out of the way of a sharp blade under tension, if you do what you really ought to do and wipe the blade down (jeans work fine) to take your fingerprints and any other corrosive agents off the blade before closing it up, you don't have a bunch of rusted spots later; and yes indeed--I've found mirrored D2 marred by little brown fingerprints over the years, in the rare cases where I've forgotten. Having to pinch the thing until the last possible fraction of a second entirely negates any attempt to clean the blade off. Over the decades, my closing method has worked fine on dozens of knives without affecting them in the least, and Queen just seems to be the King of this particular design flaw, at least of the modern slipjoints I've tried. I have a couple of GECs that sort of do it, but when the damaged area is about a millimeter long, I don't mind. It's when I have a 1/4" of dead-dull steel right in the middle of my edge belly that it bugs the daylights out of me.
All in all, I suppose this is more rant than particular question. I certainly, after modifying the knife, would not ask/expect Queen to do anything about it (though it was modded awfully cleanly, if I do say so myself) but just wish I could get their wonderful D2 in the patterns that I want without having to handle the the thing like a fragile antique every time I want to close it. I suppose it's back to carrying the Canoe, and maybe I'll give this one to my brother in law---he seems to be allergic to edges that are actually sharp, and sets about dulling them doing extremely stupid things with them from the get-go, so I doubt he'll mind this built-in feature.
Of course you should be able to let your knives snap shut. They should snap shut. I was taught to close my own Boy Scout knife at the same age by a different method which relied on the knife snapping shut. Hold the knife in my right hand by the handle with it firmly placed in my palm, finger tips pressing the knife into the base of my thumb and lowest part of my palm. Close the knife with my left hand and let it snap shut. I only cut myself when I was being sloppy.
I have a CASE knife that I have used pretty hard for about 35 years, and it snaps shut. I don't baby any of my knives - they are working tools. To me, the backspring assists and holds them open, and in the reverse assists in closing the knife and keeping it closed. All other knives I own snap shut as they should, although some are now pretty slow.
You are much more patient than I am with the current state of pocket knives. When I buy one now, if it is more than just sharpening or an easy reprofile and sharpen, I send it back. I am tired of not getting what I pay for. I don't pay to buy a product I have to rework to get it to a basic standard of functionality. I wouldn't keep a knife that had a hard tap on the blade.... who should? What manufacturer should let a knife out of the plant that self destructs its own edge?
I have feel bad for you getting that many Queen knives with problems. *KNOCKING ON WOOD* I have bought a few Queens in the last 3 - 4 years, and all but one have been great. I think that may have as much to do with the man I buy them from as anything, but as you pointed out Queen can make a good knife when they want to. Right now, due to their designs, price, and their great D2 they are my favorite maker.
But if I get a bad one, like any other defective product, it goes back. It is not my responsibility or desire to be quality control for any company, nor to repair their mistakes when purchasing a brand new product.
Rather than to tolerate that kind of inferior product, I think if more folks just sent them back the vendors would quit carrying them and possibly the manufacturers would be more careful.
Or of course, go out of business like most American makers.
Robert
I don't remember when I started reading this post... but it's late now... just teasing! ;)
I have never had a problem with a Queen made knife edge contacting the backspring... though most of my Queen made knives are older and branded Winchester or Robeson. Some folks noticed a problem on the 2012 forum knife which was made by GEC... I don't recall it being a problem on my knife... need to double check though. The Douk-Douk knives are the only knives that regularly have this problem... at least in my experience.
Edit... I'm thinking of the Mercator K55, not the Douk-Douk.
Last Edit...I promise... :p ...I own or have owned 6 or more sowbellies, 4 or more stock knives, 3 moose, 4 whittlers, 2 congress, and 3 bull heads from Queen. Maybe the problem that you are experiencing is more common on another pattern?
I have a couple of older Laguiole knives that don't have kicks at all, they have a saying “resort silencieux vivra vieux”, (silent spring will live longer). It's a pain and sometimes when I carry them I forget and snap them shut and cringe, the thought behind the Laguioles original design without the kick was that you would own one knife in your lifetime and there would be no need to file down the kick to get the blade to rest in the handle from years of sharpening, as your knife was used in the field on the farm and at home to eat with.
When I was at the factory store a few months back, the first and only knife I took a good look at had a dented edge on it. I politely gave it back, said thanks, and walked out. It's a shame really. Don't they look at their knives as they're making them? I like the Queen patterns and I really want to like their knives, but I won't buy any until they get their QC together.
t1mpani....I had a similar problem with a knife...I had clearance ground the spring at the point of contact...then re profiled the tip...by depressing the blade when closed I could tell I had clearance( plenty of it too)...but upon snapping shut...flat spot... Got so frustrated that I finally tightened up the action a little bit...now I can let it snap shut and no problems...
Wonderful rant, hopefully Queen is reading. I had the same problem, took a tiny piece of a paper match stick and stuffed it in under the kick, worked great.
Regards
Robin
Midnight flyer---overall, I think you're correct, however I can generally do mods so quickly and easily that I am willing to be beguiled by a particularly beautiful piece of bone, stag, or whatever, and twenty minutes later will have successfully "removed the evil". In this case, however, I was defeated. It's not that I couldn't remove more metal, but the look of the knife would start to change dramatically with much more off.
Hey now, when's the last time you read or heard a succinct rant? :D
It is the LEAST common on true whittlers, as they have two springs tensioning the main blade, and it's almost always the main (longest) blade that this happens with. Also, knives without a half stop are less prone to it, as they're not getting accelerated in the middle before closing. I can't--off the top of my head--remember every Queen I've run into it on, but every single one of the newer File and Wire tested Schatt and Morgans I've had (with the exception of the lockback hunter) exhibits this, and Queen makes them. It's somewhat more expected on these, just because their blades are longer and have even more momentum in closing, but again I have some pretty big Case trappers with equally long blades and stiff actions that don't smack their edges. The other Queen I can think of without being at home to look at my knives is a City English Jack that was bad about it. None of these knives has the problem anymore, but the fix was material removal like I tried to do on this one, and none of them required as much as I did to this one.
Mind if I ask how you tightened the action? I'm much more used to working with fixed blades (in terms of tinkering with them) than folders.
I have three Queen folders that dent the edge on snapping closed, two Peanuts and the Dan Burke Barlow. I reprofiled and sharpened them, and am now careful closing them. With the Peanuts it's easy, but the Barlow...I know some have had fantastic examples but mine isn't one of them. Some blind person did the grinds on the blades, the Wharncliffe was ~40 degrees one side and 25 on the other.
On the other hand, all but one of my S&M knives as well as my Colonel Coon's and a D2 maple whittler are fantastic. So I keep buying them because I like them, but have had to buy a lot of sharpening supplies too.
AMEN!
This sort of thing is something that bugs the hell out of me, especially when a knife comes from a well respected maker. There are knives designed such that the edges rest against a wood or plastic liner/handle. But no reasonably designed knife should allow the edge to make contact with its own metal backspring, ever. Kudos to knifemakers like AG Russel (and even SRM) who use a stop pin to prevent such things occurring.
OK....
Truth be told, at least part of my decision "send 'em back" is because I really screwed up a nice, one of a kind knife. I had lusted after this one, and finally got one. It had a couple of flaws that I decided to try to fix...
I actually ruined the knife. No details needed, I was just tinkering and adjusting and got a tiny bit too aggressive and then it was all over. The knife is ruined. Lesson learned over here.
After thinking on it, I was angry to feel like I had to fix a simple QC issue on an $80 knife. Why should I? I spoke to the manufacturer and they told me I should have sent it in to them or simply returned it to the vendor. They didn't know if they could do anything with it either, but neither did they think I should do their QC.
Besides, I consider myself a craftsman in my trade. I don't get paid anything if my product isn't correct. I wouldn't consider thinking that a client should do my QC. So I think if I have to step up and turn out a quality product to earn my bucks, others should have to turn out a quality product to get those same dollars.
Robert
Peen the kick!
This from Charlie (waynorth) about a year or so ago.
One of the common repairs for a "striker", was to peen/cold forge the kick out a little, which raises the blade slightly. It can often be done with a punch. The kick is usually tempered back along with the tang, so it is softer than the rest of the blade. I've done it twice, and it is simple and works!
Also, try using a narrow Jeweler's File to relieve the inside of the backspring just a smidgen where the blade edge touches it.
Peening the kick sounds like a good idea.
:p
I don't have any of the F&W knives but I've been tempted by the sowbelly. This is one of my Queen whittlers. I also have a yeller Winchester ceegar whittler but I don't have a photo of it. The other two are lockback whittlers (sold one and kept one)... I think that's it... I'll double check the yeller one since I haven't carried it yet... nope, it doesn't strike ...but it was made a while ago (1991). I don't recall the age of the Queen Classic whittler.
I'll probably try kick-peening. I mean, I already can't sell (at least not as new) or return the knife, so what have I got to lose? :D
supratentorial---I have that very whittler in dark jigged bone, great knife!
No we shouldn't full fall snap our slippies closed. I snap mine shut going into my pocket off
my leg and jeans. With those two statements they should not hit the inside of the hump on
the spring Period.
Ken.
I don't mean to imply that they should be closed as hard as you can figure out how to close 'em (body slamming, etc.) but just like you say, roll it closed on your leg or in your hand. None of the knives I've ever bought from you exhibit this behavior, Ken. ;)
One thing that drives me crazy about Queen is that one time I get a knife that has to be completely reprofiled, the next time I get one that shaves out of the box. Just picked up a dogleg jack in D2 with curly maple handles and it's almost perfect and is sharp as heck. Where's the bang head icon? :D
This is a sweet knife, gotta get a pic this weekend...
