Hello, I have been stropping for a long time, usualy on cardboard cause im cheap and it works or a old leather belt. Then i finally decided to make a real strop, I ordered some leather strips from lee valley tools. I then Picked up a piece of wood from work, about 10" long and 2" wide and 3/4" thik and glued the one piece of letaher to one side and another piece on the other, one with the smooth side up and one with the rough side up. Then worked the wood into a handle at one end(with my buck 110 cause im way to cheap to buy power tools
) and 30 min later(minus glue cure time) i have a fully functional strop that actually looks ok. This is a cheap project that will give you something solid to strop with and cost next to nothing. And the best part is you made it with your own 2 hands. I then tested it on my 110 and got it so darn sharp i cut myself a little feeling the edge, i have never been able to get it that sharp stropping on cardboard. BTW i am using the Green Veritas honing compound on the leather. Will post pics after my Tung oil shows up and i give it a few coats. looks a little rough right now with no oil on the wood.
