For me, the Charge TTi is the best multi-tool ever. Other brands have their good points, I can understand why many folks prefer them, but the TTi satisfies my requirements better than any others I've tried, and there have been quite a few.
After some years of going through a number of multi-tools, including Swisstool, Spirit and several different models of Leatherman, there remains a modest number of Leathermen and SAKs in my rotation. Of these, I consider the Charge TTi my "default" EDC, the one I would keep in the "What If Only One" derby. There are only two things I don't like about it; the combo tool cap lifter doesn't work on most bottles unless one of the handles is folded out (minor) and no awl (for me, major), could have been a deal breaker if I hadn't found an awl mod that fits the pocket clip/lanyard ring slot. Others have noted it doesn't have the same degree of fit and finish found on Vics, but it is still very well made and tough enough for the most demanding uses.
Everything else is great: one-hand opening is a treat and a big help when the other hand is occupied (usually); a quality PE blade that makes carrying a dedicated folder unnecessary (you can if you want
); a serrated blade with well done serrations on the proper (right for the right-handed) side; sharp cut screwdrivers, best I've seen on multi-tools; good saw, equal to the industry standard Vic, IMHO; double file with best ever diamond side; bit holder system that allows for unmatched compact versatility; excellent needle-nose pliers that open wide; okay scissors, not up to version 1, but good enough; comfortable grip; and reasonable weight, a good balance between carryability and enough mass to get the job done.
I certainly hope you enjoy your Charge as much as I do mine.
